What are the Pro's and Con's of running a 16v battery. Can everything run off of it like electric water pump, tach, trans break, air shifter, I run an external coil Mag or will it screw everything up because of the higher voltage. Your help is greatly appreciated. Thanks Rusty
Blown 4cyl's to the front
Do you run a Alternator?
By the way, I love that you gave been running a 4 cylinder for ages now!
Steve25 No I don't run an alternator. Yes I have been running a 4 cyl for 48 years this year. Too old and dumb to stop lol
16v is what I have run for a long time -- everything is happy , water pump spins faster, fan faster , for power out of coil, cranks over faster -- ect ect. I also run a 16 volt 100 amp alt. as my fuel injection takes a lot of juice -- esp the fuel pump. only issue i ever had was with a Radiator fan -- guess the 18 plus from the alt was to much.
The pros are what cgiese stated. I did burn up 2 CSR water pumps in 2 weeks after I switched even though they assured me the would be fine. I now have a 16v battery with a 12v tap that I run my water pump with. Everythig else runs on 16v and is happy. The cons are if your battery charger takes a crap at the track and no one has a spare for you to use. I did find that if I charge the battery with a 12v charger on the 12 v post it will charge the whole battery. I'm not sure if that's a good idea but it got me through the weekend. The other problem is finding a good 16v battery charger. the only ones I have used are a couple different XS battery chargers. I can get them to last about 2 years before they take a crap with the last one only lasting just over a year. I have 5 dead ones I need to send back to be fixed. They told me it be roughly $100 each to fix plus shipping. I've ordered another brand that's made here in the USA that has a 3 year warranty. Hopefully it last a lot longer than the XS stuff and is more reliable.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion 2024 Chief of the Pontiacs |
The XS stuff has been redesigned -- and a lot of the older stuff cant be rebuilt now because of parts issues. But just in case -- I got the 60 amp charger -- and a 30 amp for back up --
Check out 14 volt batterys as well.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
