Old 10-18-2021, 10:52 AM
Jonsie Jonsie is offline
Default brake fluid capacity
Hey fellas- I swapped out all the old brake lines for new, what is the amount of fluid needed to fill up the system? Standard power brakes, '66 GTO. Thanks
Old 10-18-2021, 12:42 PM
A quart will be probably be enough but it depends on how much you have to bleed it. 2 quarts should be plenty. If you live near a parts store buy a quart and go back for more if you need it. Try not to buy more than you need because it absorbs water once it is opened.
Old 10-18-2021, 01:01 PM
That's what I'll do, thx!
Old 10-23-2021, 09:42 PM
FWIW - system took maybe a pint of brake fluid
