Old 10-19-2021, 08:13 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Default Motor is Finally back in the Firebird
Got the 535 in the car finally. Still have to do some work to get it running.
* Hook up fuel system and carburetor
* run the oil line to the new pick up location at the front of the block
*hook up cooling system
*Finish the new exhaust. I spent today making adjustments to the headers to get them closer to the floor and create a little more ground clearance. Also finished the exhaust from the collector to the X crossover. I had it on and off many times adding pie cuts to tighten up clearance. The 3.5" exhaust will be about 1/2" higher than the 3" when I'm done.
The Following 2 Users Say Thank You to Scott Stoneburg For This Useful Post:
Old 10-19-2021, 08:19 PM
grandam1979 grandam1979 is offline
Looking really good.
Old 10-19-2021, 09:43 PM
Dragncar Dragncar is offline
Sweet, Get everything ironed out and lay down some numbers.
Good luck with her.
Old 10-20-2021, 01:28 PM
SRR's Avatar
SRR SRR is offline
Nice!
― Calvin Coolidge
Old 10-20-2021, 01:39 PM
T/A addict T/A addict is offline
Oh Boy
Old 10-20-2021, 06:32 PM
Work is crazy for the next 2 weeks, coming up on inventory...hoping I can find a few hours here and there to try and get it started next week. Then I will finish the exhaust and the new rear shock cross member.
Old 10-28-2021, 11:20 AM
grandville455's Avatar
grandville455 grandville455 is offline
Scott will it see the track yet this year?
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 10-28-2021, 01:13 PM
I sure hope so. I worked on it a few hours Monday morning, wouldnt start. Checking for spark and there was none. Checked the MSD box, appears fine. I have a replacement crank trigger now, hoping thats the issue. My biggest problem is finding time to work on it.
The Following User Says Thank You to Scott Stoneburg For This Useful Post:
Old 10-28-2021, 03:43 PM
What did u end up doing for a conv then?
Darby
Old 10-28-2021, 03:48 PM
Im going to stay with my TranSpecialties 9" for now. Try it and see where this motor pushes the converter to. It flashed to 4400-4500 ish behind my 474, that will give me a starting point. Then if im not happy with the slip % or how it acts I think I will call T/S for a recommendation. They were pretty good at spec'ing my current one.
Old 10-28-2021, 06:24 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Why did it come back out?
Looks good in there.
Old 11-04-2021, 11:51 AM
I spun a bearing in my 474 last December. At the time I thought the 535 was really close to just dropping in the car. But there turned out to be a lot of little things i wasnt thinking about. And I decided I wanted to dyno it first. That took a couple months to actually happen. Then I Hurt a couple rocker arms while on the dyno. That took a couole months to get the repalcement parts. Now its in, started it this morning ( my issue with no spark was related to the start regard controller ) So now I'm moving on to try and finish the exhaust and re uild the rear shock crossmember. I imagine if I could have devoted more time to working on it I could have trimmed 2 months off the timeframe.
Old 11-06-2021, 02:34 PM
Got the exhaust done up to the mufflers. I started it up, its loud..lol..
ID:	577050   Click image for larger version
Old 11-07-2021, 09:01 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
please splain me......
cutting/welding the tubes? or some "other" ways? It would be nice to tighten my Hustlers up to the floor a bit
Old 11-07-2021, 10:46 AM
[QUOTE=67Fbird;6293141]please splain me......
cutting/welding the tubes? or some "other" ways? It would be nice to tighten my Hustlers up to the floor a bit[/QUOT
From the manufacturer the collectors were made to angle / aim downward. I made a couple pie cuts and rewelded the collectors to angle them back up. Had to do both collectors but not exactly the same, the passenger side was lower than the drivers side as they came from manufacturer. All the work only gained me about 1/2" ground clearance. But thats at the collector, and it has scrubbed the ground before on speed bumps and poorly angled driveway/entrance ramps.
Old 11-07-2021, 05:22 PM
grivera's Avatar
grivera grivera is offline
Exhaust looks great! What trans loop is that?
Will Rivera
Old 11-07-2021, 07:18 PM
Thanks, I'm pretty happy with the way the exhaust looks so far. I angled it and added short bends in a few places VS. my old 3" to gain ground clearance. Its about 1/2" higher and its 3.5". The damn mufflera didnt come with offset inlet so they are at an angle but I should be able to make the tailpipes turn and exit where I want.
The driveshaft loop is similar to this one by Lakewood.
Lakewood 18000 - Lakewood Universal Driveshaft Safety Loops
I dont know specifically who made this one. Ive had it forever.
Old 11-08-2021, 08:24 AM
67Fbird's Avatar
ahh....just wondering if there was a tweek method (other than cut/weld) that i was unaware of...
looks good!
Old 11-11-2021, 01:20 PM
tc's Avatar
tc tc is offline
My cousin put a long/large dia pipe in the header collector and bent it upward.
Old 11-11-2021, 02:11 PM
Did he have to use any heat or just applied pressure.? Also remember if using this method, you will have to bend past where you actually want it to be. Metal will flex or spring back a small amount.
