Old 10-31-2021, 09:40 PM
Bill Hanlon's Avatar
Default 55-60 6 x 2 barrel manifold
Not mine, just thought someone here might be interested.
https://www.ebay.com/itm/30420749818...wAAOSwbXxhac2B
Old 11-01-2021, 01:16 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
That is SO MUCH better looking than the common/ordinary U-fab ones. I'm tempted to bid... just because of the polish job!
Old 11-01-2021, 08:39 AM
Then you could have twice as many carbs on your truck.
Old 11-02-2021, 12:13 AM
Well...
I will be watching the bidding for the next five days.
Old 11-02-2021, 08:22 AM
mgarblik mgarblik is offline
I have to admit, Jack, That set-up would look pretty sweet on your truck. No idea how it would run or what exactly you would use for carbs?
Old 11-02-2021, 01:36 PM
jamesq's Avatar
jamesq jamesq is offline
It looks like it's drilled for Strombergs, just a guess.
James Q
James Quayhagen
Old 11-02-2021, 02:19 PM
padgett's Avatar
padgett padgett is offline
Trust nothing from memory but always thought a "Stromberg 97" flowed about 150 cfm so six would be about 900 (rated as a 2 bbl). Linkage would be interesting.
Web Site
Old 11-03-2021, 12:10 AM
Stromberg 97, 48, 94, etc. Used to be other 3-bolt carbs also. Trouble is that I can't grab them for a buck apiece like I did in the fifties.
Old 11-03-2021, 08:46 PM
Kingman Man Kingman Man is offline
Looked at it, just down the road a bit, but where for the carbs?
Kingman man
1955 Star Chief 4 dr w ex w/c lift
1964 Comet 4 dr
1989 Cherokee 4 dr
2000 Dodge Grand Caravan w w/c lift
2000 Kia Sportage 4 dr
Old 11-03-2021, 09:14 PM
Stuart's Avatar
Stuart Stuart is offline
A fellow in England has revived the Stromberg carburetor line and is making all new ones, as well as rebuild kits and arts (he does sell linkage for a 6x2 setup). https://www.stromberg-97.com Otherwise, you have to search swap meets and junkyards for originals.
Old 11-05-2021, 11:05 AM
61-63 61-63 is offline
cfm isn't additive on multiple carb setups so it wouldn't be 900 cfm. DK what it would be as I don't know the formula (if there is one)? Mebby Tom Vaught or Carb King or someone like that does and will chime in. Regardless of what it is that would be a neat looking setup on something with a Pontiac engine in it.
Old 11-05-2021, 01:05 PM
blueghoast's Avatar
That would look neat as all-get-out on my 57-Poncho
GT
Old 11-08-2021, 01:49 AM
Sold for $225.
Old 11-08-2021, 05:03 PM
misterp266's Avatar
This setup would look awesome!
An X2 converted to Rochester carbs.
ID:	577249   Click image for larger version
ID:	577250   Click image for larger version
" Darksiders Rule "
