64 LeMans Vert vent window spacer nut and washer?
Anyone know a source for these? I see listings for 66-67 but not 64-65.
Any help will be appreciated. Thanks, Colt.
37 Pontiac Sedan 455 700r4 94 Firehawk Supercharged 5.7 LT1 6spd. 77 Grand Prix base model, 350 pontiac 97 F250 7.3 turbo diesel 85 CJ7 Laredo 65 Impala SS 396, 4 spd, A/C. |
Not sure what you mean by spacer nut. Anything in the pic resemble what you’re looking for?
I recently rebuilt both of my vent window assemblies and all of those parts are contained in a kit; never saw the parts available separately. However, the nut is a standard ¼” x 28 size. The kits are on Fleece-Bay and Ames also sells them, #F215WD. The hardware kit is the same for all 64 and later A-bodies no matter what year/style. |
This spring washer.
That is known as a roll pin. Ames has them for the 64/65, #F212. My guess is other resto places carry them also. These roll pins are common and come in different sizes so you could take the pin and try and match it up a hardware store or auto parts store. The outside diameter is what is important. If you find one with the correct diameter but is too long just file it down.
Might be talking about the bellville washer that keeps tension on the handle. Also found in a good hardware store.
"Bill"! |
That makes sense—I had a brain freeze as I always referred to them as wave washers. Learn sumtin’ new every day. Mine broke during disassembly and I did find some at the hardware store but the smallest ones were a bit too large and stuck out over the handles. Maybe the OP will have better luck. Ended up buying the handle kits as mine were pretty much trashed.
Thanks! The bellville is what I'm looking for.
