Old 11-19-2021, 03:46 PM
Andy70RA3 Andy70RA3 is offline
Send a message via MSN to Andy70RA3 Send a message via Yahoo to Andy70RA3
Default 70 TA hood scoop to air cleaner wing nuts
As I don't know if what I've seen are original or not, are they black oxide? and does anyone have a picture of an original? What is the most accurate repro available? Thanks! Andy
70 white TA RAIII
70 blue TA RAIII
72 white TA
72 formula 350 (my first car)
Old 11-19-2021, 04:12 PM
70TA-RAIII 70TA-RAIII is offline
I believe mine are original. More like chrome plated.
Name:	TA Wingnuts.jpg
70 TA RAIII M20 05D
70 TA RAIII M20 06B
Old 11-19-2021, 04:17 PM
jhein's Avatar
jhein jhein is offline
That's exactly what mine look like.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
Old 11-19-2021, 05:48 PM
1971455HO's Avatar
1971455HO 1971455HO is offline
!/4"-20 the originals were polished chrome. But they do tarnish and eventually rust a little. my old originals looked pretty rough.
I went to Lowe's and bought two stainless steel 1/4"-20 wingnuts. I compared the old ones to the new ones while I was at the store. You can't tell the difference except the new ones look great. Those are about the only thing I ever found that was inexpensive when putting these cars back right.
Maybe $0.28 each.
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
The Following User Says Thank You to 1971455HO For This Useful Post:
Old 11-24-2021, 12:39 PM
This is the one wingnut I do have...I guess it's an original...stamped "PAL"
70 white TA RAIII
70 blue TA RAIII
72 white TA
Old 11-26-2021, 01:07 PM
This is one of the wingnuts that came with my car, so it appears I have at least one original, and it's marked "PAL". Thanks for the replies! Andy
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
70 white TA RAIII
70 blue TA RAIII
72 white TA
Old 11-26-2021, 10:58 PM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
I'm sure our host here....has chrome plated stamped steel 1/4-20 air cleaner wing nuts in stock.
Old 11-29-2021, 12:16 AM
Mine are an actual tapped wing nut, not the stamped single thread style.
ID:	578767   Click image for larger version
70 TA RAIII M20 05D
70 TA RAIII M20 06B
The Following User Says Thank You to 70TA-RAIII For This Useful Post:
Old 12-01-2021, 01:14 PM
so would those be correct also?
70 white TA RAIII
70 blue TA RAIII
72 white TA
Old 12-01-2021, 01:15 PM
Maybe we could start a poll to see who has which type on their car?
70 white TA RAIII
70 blue TA RAIII
72 white TA
