Old 12-02-2021, 08:23 PM
n20ta2's Avatar
n20ta2 n20ta2 is offline
Default Pushrod length check tool for highports
I'm at the point of installing my highport heads and checking pushrod length, block is a 400 (461)zero decked and I'm using 1.65 rockers. Any idea what length adjustable pushrod tool I would order to get me in the ballpark?
1969 GTO street strip project 11.1 forged 461, highport heads
1995 Trans-am 420 ci sb 14:1 compression 9"ford
9.89@132 1.34 60ft SOLD!
Old 12-02-2021, 08:51 PM
Mean Green's Avatar
Mean Green Mean Green is offline
Pushrods are 10.200-10.250 on both sets of High Ports I have.
www.lancablingsolutions.com
Old 12-03-2021, 10:15 AM
lakefect lakefect is offline
mine are 10.300
Old 12-03-2021, 11:13 AM
n20ta2's Avatar
If I get a tool that adjusts between 9.5 and 10.5 I should be ok?
Old 12-03-2021, 11:54 AM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
10.3 were to short for me, had to go 10.4. also had to run lash caps to help keep rockers off edge of spring retainers and had to clearance the underside. the tool up to 10.5 should be good. I have the set 0f 10.3 if you need them. they are 3/8" Trend .080 wall
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 12-03-2021, 01:00 PM
n20ta2's Avatar
Thanks Bill, if they end up working I will pm you
Old 12-03-2021, 01:15 PM
pastry_chef's Avatar
Jesel tool
https://www.summitracing.com/search/...=brand%3Ajesel
Old 12-03-2021, 02:46 PM
n20ta2's Avatar
Ooo thats what I need! Thanks for the link!!
Old 12-04-2021, 12:00 AM
LT4USMC LT4USMC is offline
What thickness head gaskets are you guys running?
Sent from my SM-G988U1 using Tapatalk
Old 12-04-2021, 09:10 AM
Mean Green's Avatar
Cometic .060
Old 12-04-2021, 10:32 AM
n20ta2's Avatar
.045 butler branded
Old 12-04-2021, 07:16 PM
.040 Cometic.
6.27@107
9.97@131
Old 12-07-2021, 05:23 PM
Dragncar Dragncar is offline
Originally Posted by pastry_chef View Post
I bought this tool and it will work but just barely. At 10.5" with the short section not used you just get two full turns of threads in each ball end.
I think pushrod check springs must be used with this tool, I would not try it with inner springs only.
At 10.25" you get a decent amount of thread engagement.
Old 12-08-2021, 01:18 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
I have the Manton kit, should give you full coverage and it comes with checker springs. They are great to deal with too.
https://mantonpushrods.com/pushrod-i...ermine-length/
Dave Polichena
