Old 12-06-2021, 02:37 PM
gto19's Avatar
gto19 gto19 is offline
Default Top dead center question
Hey guys
I’m wondering what’s going on here . I’m doing a cam swap on my 400 and when I get to top dead center at the number 1 piston my rotor is pointing to the number 2 piston. I thought it should be pointed to the number 1 piston . I haven’t even removed the old cam yet . Car ran totally fine when I parked it yesterday.
Bear with me I’m no hard core mechanic. This is just a hobby for fun hobby for me .
The motor was rebuilt last year .the original damper was sent out to the damper doctor also . I’m just putting in 068 cam . Replacing the xe268 cam
ID:	579194   Click image for larger version
Old 12-06-2021, 02:43 PM
Tom Vaught's Avatar
Boost Engineer
If you have ever hunted Rabbits, Quail, or Pheasants you know you need to lead the target.
The rotor is pointed at a spot between #2 on the distributor cap and #1 for a reason.
To get the spark in the general area of the Terminal from Idle to WOT with the Centrifugal and Vacuum advance.
If you put it exactly on #1 you will be off a tooth on the gear.
Tom V.
Old 12-06-2021, 02:44 PM
Formulajones's Avatar
You can make the rotor point anywhere you want at TDC, as long as you run the wires accordingly, it really makes no difference. But the idea is to have it in such a way that the plug wires aren't a tangled mess at the cap.
https://youtu.be/XqEydRRRwqE
Old 12-06-2021, 03:03 PM
gto19's Avatar
Thanks guys
I’m just a little confused. My plug wires are ran just like this picture out of my service manual. And my original distributor and vacuum advance is set in just Like the picture
I guess what I’m trying to get at . I read I should now mark the distributor with a felt pin at the block so I drop it in correctly when I’m done with the cam swap
ID:	579196   Click image for larger version
Old 12-06-2021, 03:09 PM
Kenth's Avatar
Kenth Kenth is offline
On your pic it looks like the rotor tip pointing in the correct direction.
ID:	579198   Click image for larger version
Name:	Ign wires.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 12-06-2021, 03:19 PM
gto19's Avatar
Awesome thanks. I like how they say plug your finger over the spark plug hole and let it get blown out . I didn’t use my finger but I used tissue paper and watched it blow out .
I’ll now mark my distributor and pull it out . I’m sure I’ll have some more questions this week .
Old 12-06-2021, 03:24 PM
Gary H's Avatar
Gary H Gary H is offline
Rotate your engine until the intake valve for the number one cylinder opens and then closes all the way. Continue rotating until the timing mark is at 12 degrees before top dead center. Install the distributor in the engine with the rotor pointing toward the number 1 spark plug wire terminal on the distributor cap, not toward the number one piston. Make sure you install the wires in a 1 8 4 3 6 5 7 2 order, counter clockwise rotation. The engine should fire off immediately if everything else is done properly.
Old 12-06-2021, 03:54 PM
gto19's Avatar
Hi Gary
Your a lot more advanced mechanically then I am . I don’t have a -12 mark in my timing chain cover . I also don’t know what rocker is the exhaust and intake . I’ll definitely have the cam out today though .
Old 12-06-2021, 07:32 PM
tom s tom s is offline
If all else fails,pull all spark plugs,put a small cork in #1(first on drivers side)turn over till the cork shoots across the garage.That will get you close enough to TDC.Tom
Old 12-06-2021, 07:50 PM
steve25 steve25 is offline
Gary H has discribed the exact way the factory does it!!
They did not have the luxury of time on the assembly line to get a motor fired over so they could run checks on it.
Doing it Gary’s way guarantees the motor will start if the started can spin it and it has fuel.
Old 12-08-2021, 04:09 PM
gto19's Avatar
Can I use my big daddy Milwaukee impact to loosen the harmonic balancer bolt ?
Old 12-08-2021, 04:43 PM
Tom Vaught's Avatar
Boost Engineer
I suppose you can do anything BUT I personally would not like to damage the Bolt Thread or the key/keyway on the crankshaft by using a impact gun. A Long Cheater and a 1/2" bar, proper socket have always removed the bolt without damage.
Tom V
Old 12-08-2021, 05:40 PM
gto19's Avatar
Tom V
Interesting I thought a impact would be safe . It’s a manual transmission car so doing it your way how do you hold the flywheel?
Old 12-08-2021, 05:46 PM
sdbob sdbob is offline
I learned a lesson. Helping transplant a Pontiac 350. I put distributor in as I watched the valve close,only thing it was the exhaust valve! I was tired and in a hurry. Funny how mistakes make you wiser. If I can remember them.
Old 12-08-2021, 08:10 PM
gto19's Avatar
What’s the trick to sliding the small timming gear off the crankshaft? The big gear on the cam slides easy but the small gear isn’t moving . Trying to remove the timing gear set
Old 12-08-2021, 08:40 PM
I use two lady foot pry bars on the bottom gear. Regular claw hammer will work if its not too tight.
I would go ahead and put the old cam in time on #1 cylinder before you pull the gears off. That's one crank turn from where you're at. Pontiac is dots together instead of dots up.
Do note the nose of the cam sticks all the way through the cam gear. That little bit sticking through is what the fuel pump eccentric fits on.
When you get ready to tighten the crank bolt... crawl under the car and take a shift rod loose so you can put the transmission in first and reverse at the same time. Then the crank can't turn as long as the clutch holds.
Clay
Old 12-08-2021, 09:05 PM
gto19's Avatar
Darn to late . I got the timing gear off . I noticed that with the dots . Can’t I just put the timing gear back exactly how it came out and reinstall the distributor the exact way it came out ? I marked it with a pin and took a picture
How do I pull the cam out now ?
Old 12-08-2021, 09:18 PM
Schurkey Schurkey is offline
Find the longest bolt you can, (6+ inches) that has the same thread size and pitch as the bolt that holds the cam gear on. Run that bolt into the front of the cam, use it as a handle to pull the cam out.
BE CAREFUL that you don't nick the cam bearing(s) with the lobes or the cam journals. Don't lose the cam thrust plate, or it's bolts, either.
Old 12-08-2021, 09:38 PM
Actually dots up is #1 on Pontiacs.
I usually use the together way because it's easier to make sure the dots align.
With the dots together the crank/cam is on #6 firing order.
Dots up is #1 firing.
Old 12-08-2021, 09:53 PM
Tom Vaught's Avatar
Boost Engineer
Very good advice by several here.
Obviously you have already removed the intake, valley pan and the the lifters and pushrods.
When you are ready to remove that camshaft with your 6 inch long bolt threaded into the end of the camshaft, I personally have always used a coat hanger (stretched out) with the coat rack loop inserted under the back of the camshaft.
This seems to help with not damaging the camshaft bearings as you slide the camshaft forward slowly.
Depending on the chassis you are removing the cam from you might have to remove more than the radiator to get the cam all the way out. I always had to remove the bolts to the 64 GTO hood release (on the radiator support not the hood) to get the camshaft completely out of the engine.
Tom V.
