Old 12-25-2021, 11:56 PM
GtoFM's Avatar
GtoFM GtoFM is offline
Default Engine stand wiring diagram
My '66 389 is in the car ('64 GTO) but all wire harnesses have been removed for replacement. I would like to start the points distributor engine for a short test run. I figure the basic wiring used on an engine stand should work. Do I need the resistance wire to save the points?
Does anyone have such a diagram? If not, I have a mech/elect past so I can figure it out. Am I making this too difficult?
Old 12-26-2021, 03:55 AM
dataway's Avatar
dataway dataway is offline
I wired in a switch to add in a resistor after the engine was started ... basic engine stand wiring with an extra toggle that said "start" and "run" . Forget the specs, but it was a high wattage 3 ohm ... something like that, maybe 1.7 ohm?
Old 12-26-2021, 04:19 AM
I used a Mopar ballast resistor. They are cheap and most parts stores have them. You don't need a full 12 volts to start your engine If you are inside or in a warm climate. You don't need a switch if you use an alligator clip on either the coil positive or battery end.
Old 12-26-2021, 07:17 AM
dataway's Avatar
Yep, I think that's what I used ... one of those long rectangular Mopar resistors.
To be honest, like Goatracer says .... I usually don't even use the switch, just leave in the "run" position all the time.
