Early T/A dash bezels
I have a couple of what I think are early T/A dash bezels that I want to clean up. I think these are 1970 and 1971 since that is what they were labeled.
The bezel I think is a 1970 has black rings, and there is a yellowish tint in various places. I believe this is out of a late production 1970. What can I use to clean the yellow off? And was this some type of coating that has disentegrated over the years? I think the second bezel is a 1971. Somebody had a small plaque stuck on the right side with double sided adhesive tape. There is also some blotchy patches that appear to be some type of adhesive. The first pictures are of the 1970 bezels. What is the best way to remove the yellow and adhesive from these dash bezels? |
Here are the pictures of the 1971 bezel.
Also, I think these are 1970 & 1971 because the lights and wiper are split. Can somebody confirm. |
Bezel
Those are cool. I read some where that they center the bird too . These are mine.
The yellowing is in a clear coating. Not sure of the original material but I used lacquer thinner to clean mine up and then re-coated with clear lacquer. That was 20 years ago and has held up well.
That '70 TA non-AC bezel is a hen's tooth these days.
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
Recoat
So how you remove the whole lacquer coat?you said paint thinner?
The bezel I have marked as a 1970 came off of a late car. I'm going from memory, but I think the cowl tag had an 07B date on it.
What color should the rings around the gauges be? Black or chrome? |
For many years I thought 70 was chrome, 71 and later black, but as I’ve seen more cars and talked to owners I’ve come to the above beliefs. I am interested in what others think on this. |
there are a couple guys that do top notch restorations on these if its worth the price for your car, look up randy combs if you want to go that route. |
FWIW.......I have owned my 71 TA since 1998, it has a build date of 9/70 and has the chrome rings. Bought it from a friend who only owned 71's and 72's so he had no reason to change them.
jon |
At least one dash bezel will be for sale once I get them cleaned up.
As for the rings, how did the Van Nuys plant differ from the Norwood plant? I'm assuming GM used suppliers to make these parts, so it's possible the Norwood plant used a different supplier. It's also possible there were different suppliers to the same plant. A lot of time an engineering change is written to "Use up existing". So if a supplier was supposed to change from the chrome rings to black rings, if the manufacturing engineer agreed, the supplier could use up the chrome rings rather than scrap them. |
Mike, if you have a damaged later model TA bezel laying around ... do a little practice on it first .
Or find one somewhere. Once the "old clear" layer is penetrated things can go downhill fast on the engine turn swirls. It is very delicate to any rubbing pressure on its open surface. Especially where you have the glue residue - extra caution. Will probably go through the clear in the surrounding area before the actual residue is fully removed. The swirl is delicate and unforgiving to any oops or woops I got carried away / forgot. |
Orange Oil furniture polish works nice on them. Or they can be clear coated with satin or gloss. |
Total crapshoot on whether they got the black rings or the chrome rings - no obvious rhyme or reason. More black than chrome at the start of the model year, and more chrome than black toward the end (with the chrome running into the early '71 cars, as noted). No real difference between Van Nuys and Norwood in this regard, either. Just eyeballing all my data entries, I'd say it was about 50/50 on chrome vs black for '70.
I agree with Keith, some 70's got chrome and some got black, no obvious reason as to why.
On the 71's, my old low-mileage Trans Am was built mid-February 1971 in the Norwood plant and it had chrome bezels on it. |
Great info! Both of my 70's have chrome rings so I thought all 70's should have chrome rings.
John
70 TA RAIII M20 05D 70 TA RAIII M20 06B |
Are both yours Norwood built?
Yes they are.
