Old 01-07-2022, 12:32 AM
1965 Pontiac Parisienne's Avatar
1965 Pontiac Parisienne 1965 Pontiac Parisienne is offline
Default 1965 389 Carter 3896s AFB question …
Just rebuild my Carter ..
there a discharge needle in the carb kit .. for the center jet housing .. but at my carb there wasn’t any needle or ball placed …or came it out during cleaning blow out ? have all Carter AFB this needle ? Or I’m wrong ….. check ball or needle ?
I’m confused what to do … book days needle ..other illustration shows ball
Thx Björn
ID:	581520   Click image for larger version
ID:	581521   Click image for larger version
ID:	581522   Click image for larger version
ID:	581523   Click image for larger version
1965 Bonneville 2 door coupe nightwatch blue AZ car
1965 Bonneville convertible starlight black
1966 Star Chief Coupé
1965 canandian Parisienne custome sport convertible AZ car. „Sold“
1977 california Firebird Esprit [/SIZE][/FONT]
Old 01-07-2022, 12:57 AM
You must have something in the accelerator pump outlet. Most of the AFB carbs that I have done (and that's a lot) have had the needle valve.
Old 01-07-2022, 01:08 AM
Sirrotica's Avatar
As I remember, and it's probably been 30 years since I've done an AFB, there's one in the accelerator pump well (ball) and the needle under the discharge nozzle (#42). I used to do them all the time back in the 70s and 80s, but the demand to rebuild AFBs just went away when the cars they came on were no longer road cars. The last one I did was for a 61 Bonneville in the 90s.
I may be wrong about the ball in the pump well, you can forget details over 30 years, I'm sure of the needle under the discharge nozzle, that is clear for sure.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 01-12-2022, 05:03 AM
Kenth's Avatar
Kenth Kenth is offline
1957-1958 1:st design Pontiac Carter AFB´s uses #116-13 5/32" steel pump check ball.
1958 2:nd design-1965 uses #17-51 brass pump check needle.
1966-1967 uses #116-25 1/8" aluminium pump check ball.
HTH
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
