Old 01-14-2022, 02:45 PM
bhill86's Avatar
bhill86 bhill86 is offline
Default Source of coolant leak
I climbed under my car today (77 Trans Am with a 69 400) for the first time in a while and noticed some fluid on the floor. It ended up being coolant that was dripping from the rear the engine/fly wheel area. I looked around the front of the engine near the water neck because I’ve had issues with that leaking before and running down the valley pan but that area was dry still. I could definitely see fluid pulled around the area of the distributor and back of the valley pan so I’m thinking the only other culprit could be the intake gasket for the water crossover. Does this seem likely or is there somewhere else I should be looking too?
Old 01-14-2022, 02:47 PM
It could be a freeze plug in back of block.
The Following User Says Thank You to tjs72lemans For This Useful Post:
Old 01-14-2022, 02:49 PM
Verdoro 68's Avatar
Could be as simple as the hose clamp on the heater hose nipple on the back of the head.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 01-14-2022, 02:52 PM
bhill86's Avatar
True I didn’t think about checking that. I ran out of garage time and have to leave for work but I’ll check it.
The Following User Says Thank You to bhill86 For This Useful Post:
Old 01-14-2022, 02:53 PM
bhill86's Avatar
That’s what I was originally afraid of but I figured with the coolant on the valley pan back by the distributor my chances were better that it isn’t a freeze plug.
Old 01-14-2022, 03:08 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Check the intake bolts. Give em a good snuggin to see if any are loose.
Old 01-14-2022, 04:15 PM
bhill86's Avatar
Worth a shot I guess
Old 01-14-2022, 04:46 PM
Gary H's Avatar
Gary H Gary H is offline
I vote rear heater hose.
Old 01-14-2022, 04:49 PM
PunchT37's Avatar
Always start with things that don`t cost anything. Then, move on. If it doesn`t work, oh well. No money lost.
The Following User Says Thank You to PunchT37 For This Useful Post:
Old 01-14-2022, 06:11 PM
equidr equidr is offline
I would go to the local parts store and borrow a cooling system pressure pump. That's the easiest way to figure it out.
Who cares about the horsepower wars, Indians win the torque wars.
Roger
The Following User Says Thank You to equidr For This Useful Post:
Old 01-14-2022, 08:47 PM
bhill86's Avatar
That’s not a bad idea. Hadn’t thought of that either.
Old 01-14-2022, 09:49 PM
ZeGermanHam's Avatar
Given the circumstances described, this would be the first place I would look. If it's dry, then continue looking in the other areas suggested above.
1998 BMW 328is (track rat)
Old 01-14-2022, 09:59 PM
Sirrotica's Avatar
This, I've seen pin holes in the heater hose show the same symptoms.
Pressure tester may show you exactly where it's coming from, this is usually the way a mechanic approaches this type of problem, and why I own one.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 01-15-2022, 12:16 AM
Formulabruce's Avatar
Here is my take having seen this in a few Pontiacs, starting with my 428 GP.
The drivers side head water outlet area to the intake gasket has a tiny leak, on the bottom side.
So where does it go?
Along the TOP Edge of the valley pan, to the Dist area.
Could be intake is pitted or need a clean up, or failing gasket.
all IMHO....
" Long may we DRIVE !"
Old 01-15-2022, 09:50 AM
69hardtop 69hardtop is offline
Heater hose…..borrow the pressure tester from O’Reillys or whomever and you’ll have your answer quickly (mine was loose heater hose, just a few drops that would puddle by distributor - but when I pressurized it easy to see leak)
Old 01-15-2022, 10:15 AM
PunchT37's Avatar
all IMHO....
Yep. That’s why i said to check intake bolts earlier. Have seen that a few times too. Problem is actually hidden in the front.
Sometimes the gasket is not toast yet. Snug the bolts down and leak stops.
Old 01-15-2022, 02:52 PM
bhill86's Avatar
I’ll try all that out and report back
