Old 01-15-2022, 10:03 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Default 1968 Pontiac Ram Air Quadrajet 7028270
Completely/correctly rebuilt and restored with colored castings and zinc plated small parts. Bronze bushings installed in the baseplate and modern internals to hold up in this new fuel.
I will also custom calibrate for engine modifications if/as needed.
Original carburetor part number 7028270 for the 1968 400 Ram Air engines with the auto transmission.
Asking price is $3000.
PM, Email or call the shop at 740-397-2921 for more info......tks....Cliff
ID:	581947   Click image for larger version
ID:	581948   Click image for larger version
ID:	581949   Click image for larger version
Old 01-15-2022, 06:22 PM
Carousel72TRed's Avatar
Carousel72TRed Carousel72TRed is offline
Boy too bad I’m one digit off with a 7028269 I’ve had sitting in my toolshed forever. How much to rebuild a 7028269 and can it be used for my 69 GTO 400 auto trans, Holley Performer manifold, cam 475 lift, 280 duration, stock 3.23 rear end.
Old 02-25-2024, 03:16 PM
moparcolt's Avatar
moparcolt moparcolt is offline
Cliff, do you still havevthis carb?
Sent from my SM-G973U using Tapatalk
Chris Collier
1969 firebird, pro touring build. Full Global West suspension 474 Stroker with Molnar Crank and Rods, DCI Ram Air 5 Top end, Holley fuel injection, Vince Janis 200-4R trans
"There is no such thing as too much horsepower"
