Old 01-30-2022, 12:25 PM
BirdBrain BirdBrain is offline
Default Who makes the correct blue interior dye for 1970 Trans Am?
Who makes the correct blue interior dye for 1970 Trans Am? Any recommendations as to which manufacturer's color is more correct?
Thank you
BirdBrain
Ambition is a dream with a V8 engine. -Elvis
Old 01-30-2022, 04:41 PM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
Thank you
BirdBrain
There is no such thing as vinyl die....It is actually paint...
Vinyl is not porous...and will NOT absorb anything...
Have yet to find a close match.....
Best to take a nice original sample to any autobody paint supply house and have them mix up some SEM....to match..
The Following User Says Thank You to Green Hornet For This Useful Post:
Old 01-30-2022, 09:27 PM
RamAirPwr RamAirPwr is offline
A fellow PY member mentioned that the paint from Corvette America is very close. Bright blue was used on Vette's in 69 70
https://www.topflightautomotive.com/...=Bright%20Blue
Also Kolor Korrect who apparently work with Legendary Interiors
https://kolorkorrect.com/
1970 RAIII white/blue
Old 01-30-2022, 10:55 PM
Just Dashes mixed some up for me when they did my dash (since they only use black vinyl, it needed to be colored). I had them mix up enough to do the rest of the interior panels as well. That was 20 some years ago, but they're still in business, so might be worth checking with them.
Name:	Interior Rear LH B Pillar.jpg
Old 01-30-2022, 11:58 PM
Still looking good!
Old 02-01-2022, 12:18 PM
dld's Avatar
dld dld is offline
I was probably the one that suggested the Corvette America paint. that they call dye. As mentioned it is a paint, but formulated for plastic and vinyl
as said in prier post the white and the blue on a 70 T/A are 69 70 corvette colors
A couple pictures of there aerosol.
side panels were sprayed ,touch up on seats (not center comforter weave), the console was new Blk.
ID:	583311   Click image for larger version
ID:	583312   Click image for larger version
Old 02-01-2022, 12:24 PM
dpoltzer's Avatar
dpoltzer dpoltzer is offline
Default AL Knoch in TX
Bird; I had my Dash redone by AL Knoch in TX (915-886-5800)and they did a great job. I also had them mix up a qt. of Bright Blue paint for the rest of my interior and it looks great. You might give them a call? Dave
1970 T/A
