Old 02-10-2022, 07:24 AM
Frank69 Frank69 is offline
Default Rear Main leak 350 V8
Friend has a 350 v8 Pontiac that has rear main leak. Does anyone have a remedy for this other than engine removal? Thanks, Frank69
Old 02-10-2022, 08:14 AM
ponyakr's Avatar
ponyakr ponyakr is offline
I did it in my '69 GTO, only once, back in the early .70's.
Worked just fine. I then raced it in '73 & '74, having never removed the engine.
But, I was MUCH younger then.
Wouldn't attempt it now.
Would pull & try a 1-piece seal. Most say they work good, in most engines.
Old 02-10-2022, 09:44 AM
Thanks for the info.. Good suggestion. Frank69
Old 02-10-2022, 09:46 AM
Thanks for the info. Good suggestion. Frank69
Old 02-10-2022, 10:48 AM
tom s tom s is offline
I have not had any failure with the BOP 1 pc seal.50/50 with the 2pc.Tom
Old 02-10-2022, 02:12 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
I would verify it is an actual rear main seal leak 1`st. Oil pans are famous for leaking back there. Valley pan, dist gasket, etc.
The Following User Says Thank You to PunchT37 For This Useful Post:
Old 02-10-2022, 05:29 PM
After close inspection it looks like both valve covers are leaking down back side of engine. Thanks Punch T37! Frank69
