Old 02-16-2022, 03:01 PM
Shiny Shiny is online now
That's a striking body style and your work is impressive. You'll be selling viewing tickets everywhere you go. Very cool to see this brought back so nicely.
Thanks for sharing!
Old 02-16-2022, 07:22 PM
cleveweld's Avatar
cleveweld cleveweld is offline
Thanks for sharing!
Thank you Darren 639, tallrandyb and Shiny for the kind words.
I recently recovered hundreds of restoration pictures from a computer that crashed and thought others might enjoy seeing some of them.
Old 02-23-2022, 01:52 PM
cleveweld's Avatar
To properly paint interior it was necessary to paint door jambs and all interior parts of doors including window frames. I removed vent windows and replaced rubber. Also new door rubber, windshield gasket and tailgate gasket from Steele Rubber.
ID:	584753   Click image for larger version
ID:	584754   Click image for larger version
ID:	584755   Click image for larger version
ID:	584756   Click image for larger version
Old 02-24-2022, 01:28 PM
326HO-Lemans 326HO-Lemans is offline
Is silver leaf green a metallic paint?
Old 02-24-2022, 01:51 PM
cleveweld's Avatar
Yes. I think the Silver Leaf part of color description refers to metallic
Old 02-24-2022, 04:07 PM
higgenslake higgenslake is offline
Silverleaf Green Poly is the name of the color. poly means metallic.
Old 02-25-2022, 11:53 AM
cleveweld's Avatar
I didn't realize so many of the colors offered in '62 were metallic. Is Poly short for something?
Old 02-25-2022, 07:10 PM
Looks awesome. Will you paint the exterior with single stage too?
Most sources say you have to use bc/cc with metallics.
Old 02-26-2022, 12:55 AM
JSuchma JSuchma is online now
It is very hard to spray single stage metallics and keep the particles from floating.
The other issue is that single stage metallics cannot be wet sanded and buffed, unless you spray a few coats of clear last.
Old 02-26-2022, 11:26 AM
cleveweld's Avatar
I painted both Tempests pictured below using single stage acrylic enamel with hardener. The hardener gives the paint a deep glossy shine. Both paint jobs were wet sanded and buffed. No clear on either car.
The Caravan Gold coupe was featured in article below.
https://stevemckelvie.wordpress.com/...-of-an-engine/
The first time I sprayed the gold coupe, I had used too much pressure and had stripes in the paint from the metallic. After I figured out what went wrong I re-prepped the car and sprayed with lower pressure and got great results.
ID:	584944   Click image for larger version
ID:	584945   Click image for larger version
Old 02-26-2022, 10:16 PM
It seems weird they make single stage metallics and say they aren’t recommended.
I see Eastwood has this.
https://www.eastwood.com/eastwood-me...-enhancer.html
Old 03-02-2022, 12:23 PM
Cardo's Avatar
Cardo Cardo is online now
Very very cool. Love it!!
"I know just enough to keep me here, but not enough to get me out"
Old 03-13-2022, 10:02 AM
cleveweld's Avatar
Default Upper Ball joints
I bought a pair of NOS upper ball joints but found the originals to be tight and in excellent condition so I didn't change them. They were covered in crud and weren't rusty. I replaced the shaft & bushings with NOS. Also found original looking control arm shims to replace rusty originals. And replaced the Grade 8 hardware.
The original tie rod ends and adjusters were also in nice condition so I measured the lengths on both of them before taking them apart for cleaning.
ID:	586180   Click image for larger version
ID:	586181   Click image for larger version
ID:	586183   Click image for larger version
ID:	586185   Click image for larger version
Old 03-13-2022, 03:56 PM
cleveweld's Avatar
Default Lots of Parts To Paint
The automotive paint supply store was able to mix my Silverleaf Green paint using code "J". I watched as the guy weighed each ingredient on a scale so I know the color is right.
Lots of misc. parts to paint.
ID:	586215   Click image for larger version
ID:	586217   Click image for larger version
ID:	586218   Click image for larger version
ID:	586219   Click image for larger version
Old 03-15-2022, 01:41 PM
cleveweld's Avatar
Default NOS Exterior Trim Parts
I have been collecting NOS exterior trim pieces for when Safari gets painted.
In the boxes are front & rear bumper guard kits and back-up lamp kit.
ID:	586370   Click image for larger version
ID:	586371   Click image for larger version
Old 03-18-2022, 11:23 AM
cleveweld's Avatar
Default Rear Control Arms
NOS rear control arm bushings & shafts.
Misc. rear brake parts were sandblasted and painted.
ID:	586530   Click image for larger version
ID:	586531   Click image for larger version
ID:	586532   Click image for larger version
ID:	586533   Click image for larger version
Old 03-18-2022, 11:51 AM
tom s tom s is offline
Remember they painted Lacquer back then!Tom
  #38
Old 03-18-2022, 12:47 PM
cleveweld's Avatar
Default Lacquer
Sure, back then! Everything you see was painted with enamel spray cans. The control arms are painted with Krylon satin black.
The dark green paint on the Safari upper dash is lacquer base. But it's not a paint, it's Sems vinyl dye. That's why upper dash has a satin finish not glossy. Greg
  #39
Old 03-26-2022, 12:24 PM
cleveweld's Avatar
Default The Engine
The engine is the original numbers matching that ran till around 1981 when someone tried to change the fuel pump and stripped out both bolt threads in timing chain cover. The engine had 101K miles when parked.
Before pulling the engine out a friend suggested I get it to run first and test transmission. I got it to run and idle using a jug of gas to gravity feed the carb.
The cylinders are now bored 0.030" over and the cylinder head has new valves, seats, guides and springs. I bought a Heli-Coil kit and repaired the timing chain cover.
ID:	587155   Click image for larger version
ID:	587156   Click image for larger version
ID:	587157   Click image for larger version
ID:	587158   Click image for larger version
  #40
Old 04-07-2022, 02:05 PM
67SS&99SS 67SS&99SS is offline
The craftsmanship really shows in your restoration. Thank you for sharing photographs. My 62 was a factory air car and I would like to put it back on it but the only pieces I have are the shroud and the unit that goes under the dash. Where did you source your parts from for the AC system? Is it like everything else with these cars? Find good used or NOS?
Andy
1962 Tempest Lemans 4 cyl auto
1967 Camaro
1969 C/10
1969 D300
1972 K/5
1974 'Cuda
2005 2500HD Duramax
Thread Tools
Display Modes
