Old 02-16-2022, 01:08 PM
Pontiac Derek Pontiac Derek is offline
Default Can you run a 6.700” rod on an SGI 4.500” crankshaft?
Hey guys just needed to know if anyone is running a 6.7 rod on an Star Galaxy 4.5 stroke crankshaft? I’d like a little more Compression distance on my 490 build but I need to know if I have room for the shorter rod without having to cut down the counter weights?
I just haven’t used the sgi crank before Thank you
Build it Right Build it Once!!!
Just another Engine Builder from the Northwest lol
Old 02-16-2022, 01:13 PM
GTOGEORGE's Avatar
If I recall I have a 6.7" rod with my 4.5" stroke crank!
GTO George
Old 02-16-2022, 01:26 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Yes, for sure
Go fast, see Elvis!
Old 02-16-2022, 01:47 PM
GTO George
Thanks, I just wasn’t sure on the SGI crankshaft if they were any different
Old 02-16-2022, 01:48 PM
Yes, for sure
Thank you Paul
Old 02-16-2022, 01:51 PM
GTOGEORGE's Avatar
I have a Moldex cranks with Aluminum rods But shouldn't be a difference, the block maybe.
GTO George
Old 02-16-2022, 01:58 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
GTO George
More about the counter weights than the block in this case
Dave Polichena
Old 02-16-2022, 09:21 PM
That’s my concern! Thanks
Old 02-16-2022, 09:23 PM
FYI you can get SGI forged crankshafts for 621$ Shipped through their eBay store, best deal I could find
The Following User Says Thank You to Pontiac Derek For This Useful Post:
Old 02-16-2022, 10:11 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
What's different about their counter weights? I have a Scat Forged 4.5" crank with 6.7" rods
Old 02-16-2022, 10:34 PM
That’s what I’m trying to figure out SGI has a note under the Crankshaft saying you got to use a 6.8 inch rod and I don’t like using the 6.8” Rod with the 4 1/2 inch stroke crank because I think the Pistons too short so I want to use the shorter rod and so I figured I’d ask people here if they have any experience with this Crankshaft, I’ve ran shorter rods on the Scott cranks no problem and I believe that’ll be the same here it’s just good to ask before I order parts
Old 02-17-2022, 01:26 AM
ID67goat's Avatar
ID67goat ID67goat is offline
As far as pistons, is there a very big difference between the piston design for 6.7 vs 6.8 rod?
0.100" does not seem like much, but is it the difference between needing oil ring support or not? Or is there more to it?
My machine shop was trying to talk me into going 4.5 stroke instead of the 4" I have waiting in the box, and while the extra cubes would be nice I just wasn't sure about it with a stock block build.
I am thinking SGI says 6.8 rod just because the crank is 2.2" rod journal, but 6.7 should work also....
Old 02-17-2022, 01:33 AM
Yeah there is a difference between a 1.165 compression distance and a 1.275-1.3 CD As far as oil consumption, piston scuffing etc, I’m trying to run a little longer skirt to hopefully have a little less piston rock and wear.
this is a street deal, unfortunately even at 1.3cd it will still have oil ring support rails but still I believe it’s better to get the pin out of the oil ring as much as possible, jmo
Old 02-17-2022, 12:02 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
Even my 4.35 stroke 6.7 rod Ross pistons use an oil ring support. No big deal to me, I wanted to keep more of the piston in the bore at the bottom.
Illinois Outlaw Gassers
6.27@107
9.97@131
The Following User Says Thank You to Bill Eveland For This Useful Post:
Old 02-17-2022, 03:42 PM
Hooter's Avatar
Hooter Hooter is offline
Really? I run a 6.7 rod in my 4.375 stroke motor with no oil ring support needed. Did the match on the combo before ordering the custom pistons from Diamond. The pin is close to the ring land, but no support needed. Maybe I have a hair more deck height than you.
67 Bonneville ragtop
Old 02-17-2022, 04:51 PM
I got them thru Butler and thats how they came. I didnt ask before I ordered the rotating assembly so thats on me.
6.27@107
9.97@131
Old 02-17-2022, 05:15 PM
I've built 2 motors with 4.5" stroke. Both with 6.7 rods. JE Pistons did not need a ring support. Diamond pistons did.
The Following 2 Users Say Thank You to Scott Stoneburg For This Useful Post:
Old 02-17-2022, 06:29 PM
cgeise's Avatar
cgeise cgeise is offline
depends on what its used for and where you want the ring pack --
Old 02-21-2022, 07:43 PM
AIR RAM AIR RAM is offline
Im building my 496 with a 6.7 rod & 4.5 stroke crank.
SPEED SAFE, AIR RAM
"The grass is not greener on the other side, its just fertilized with different $h!t"
Old 02-22-2022, 02:43 AM
So after getting the Crankshaft today and doing some rudimentary measuring I think that there’s going to be plenty of room to run a 6.7 rod
piston should clear the counterweights no problem on this SGI crank
There seems to be some confusion I’m only talking about the SGI crankshaft in this thread I was not talking about Scat, Bryant, muldex, or any of the other companies those are ones I’m familiar with this one I was not also hence why I asked but now that I have the Crankshaft I have the answer yes you can definitely run a 6.7 inch rod and probably a 6.635-6.66” if needed
