OPGI Front Endura Bumper Is On My 1969 GTO, Pics and Details Inside
Since I couldn't find any info on this topic and can't read the OPGI reviews, I figured I'd help someone make a more detailed decision than I had the chance too.
I will try not to add too much of my opinion, but I'm satisfied with the outcome. If curious, if you do the paint blending you're looking around $5-$6k total and around $4k without at experienced, high quality restoration shop out here in IL. I purchased this from OPGI for $1000 shipped (no discount and you're paying around $190 shipping). https://www.opgi.com/Products/bumper...o-g240103.html I went to Custom Classics in Island Lake in IL and they had literally just done a GTO Judge so they had a great back to back on going this route or fixing the stock. My stock bumper has a dent and cracks galore with chipping. The OPGI bumper appeared to be of good quality and fit. They only needed to trim a little off it and add a little crown at the middle hump of it. I'm not a gap expert but the side gaps looked better than before and the middle hood gap seems a tad bigger now. They blended the hood and fenders and it's looking great again. While I don't have any info or pics of how it's holding up 8 years later, the shop seemed to think it's going to hold up better than the factory even after a ton of prep on it. If curious, I kept the factory bumper and will swap in new front headlight and grille pieces, the factory look faded now that the bumper pops.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct at 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump Last edited by GOAT8U2; 02-20-2022 at 10:42 PM. |
More pics
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct at 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump |
The Following User Says Thank You to GOAT8U2 For This Useful Post: | ||
Looks pretty good
Nice!
Looks nice. Good to hear positive results from repop parts.
looks good! irgoatmike
