Old 02-23-2022, 12:19 PM
mbeeman400's Avatar
mbeeman400 mbeeman400 is offline
Default Cast Gray or Silver - Ceramic Coated Exhaust Manifolds?
Motors out on the 70 TA and doing a rebuild. Looking for opinions on exhaust manifold finish. On SBC ram horns because they are so visible. I have used the silver ceramic coating. Thanks in advance.
Old 02-23-2022, 12:46 PM
gtospieg gtospieg is offline
I can tell you what NOT to use. I tried Por20 silver on brand new properly prepped and cleaned exhaust manifolds that were then cooked in the oven. They started flaking immediately...never again. Maybe Jet Hot coatings?
Old 02-23-2022, 01:03 PM
grivera's Avatar
grivera grivera is offline
I bought my Long Branch manifolds from RARE and had them ceramic coated. They were rusted within a year of use
Will Rivera
Old 02-23-2022, 01:04 PM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
I've used Eastwood Cast Iron Gray and it's held up very well on both my '67 Cutlass and my '79 T/A.
Mike
Old 02-23-2022, 01:23 PM
grandam1979 grandam1979 is offline
Jet hot long branch manifolds I got used in 2014 still look great.
Old 02-23-2022, 01:35 PM
AG's Avatar
AG AG is offline
Cast grey ceramic coating. I have RA manifolds silver ceramic coated and don't care for the color too much.
Old 02-23-2022, 01:40 PM
25stevem's Avatar
25stevem 25stevem is offline
To me once silver goes thru 1 heat cycle they look like a light dirt film does on polished chrome rims, so I prefer the gray cast iron look.
I do stuff for reasons.
Old 02-23-2022, 01:50 PM
Joe-Touring Joe-Touring is offline
I’m partial to the cast grey look. I used POR-15 as well and it’s held up well so far. Used the high heat formula in the spray can, and popped em in a propane BBQ to cure em.
67 LeMans, 326, M20, 3.31 12 Bolt
Old 02-23-2022, 02:28 PM
Formulajones's Avatar
For cast iron manifolds, a cast grey just makes sense to me and what I prefer to see. I save the shiny silver coatings for headers.
For the cast grey on cast iron manifolds, I prefer to use the POR15 cast grey out of the can and brush it on. I've used that successfully for many years on several cars, including my own, and they still look just as good to this day. Some of the early ones going back at least 7 or 8 years now.
https://youtu.be/XqEydRRRwqE
Old 02-23-2022, 04:32 PM
equidr equidr is offline
I used the same on my Long Branch Manifolds. 10 years later and they still look great. I drive it about 2000 miles a year.
Who cares about the horsepower wars, Indians win the torque wars.
Roger
Old 02-23-2022, 05:45 PM
I used the Por20(silver) which was supposed to be for exhaust manifolds. Never really liked the silver. If I did it again I would do cast iron gray. Maybe I should've used the Por15 instead. Either way I followed their procedure to the letter including cooking them in the oven and it just didn't work well for me.
Old 02-24-2022, 10:51 AM
78w72 78w72 is offline
x3 on good results with por15 cast iron high temp, brushed it on 301T manifolds & the wastegate 10 years ago & still looks good, looks like real cast iron. i used a mix of the por15 & por20 on the up & down pipes for a darker silver-grey color that is holding up very well & looks good.
used the por20 silver on some new headers & it looked great & lasted for about 4-5 years but then started to get rust through stains & now after 10+ years its rusted through in many areas but held up further down the pipes. i plan to sand them down the best i can & try the VHT in a spray can, have seen it used on other motors & it holds up pretty good, but nothing will last on headers besides real ceramic coat.
strange that a ceramic coating rusted in a year, must have been applied wrong or was defective. i used a local shop to ceramic coat the hooker super comps 6 years ago & its holding up great after dyno time, lots of street miles & a whole bunch of drag strip runs.
Old 03-01-2022, 08:39 PM
mbeeman400's Avatar
Thanks to all for their comments and suggestions. I am going with cast gray ceramic coating. Ill try to post some pics when they are done.
