Old 02-27-2022, 08:15 PM
Malibu Malibu is offline
Default 69 GTO conv - rear wheel cylinder slider pins position
Hey folks,
Not sure if that's the correct name, but I had a question on the 2 pins that go into the rear wheel cylinder. Just installed new cylinders and those pins seem to stick out more than when I had the original cylinders. When I installed the brakes it seems the pins then compressed into the cylinder pushing it in. Is this correct? I thought without the brakes engaged the cylinders would be at neutral resting state instead of compressed. Appreciate any feedback.
Thanks!
Old 02-28-2022, 02:40 AM
dataway's Avatar
dataway dataway is offline
The "rest" position of the actuator arms determined by the shoes seating on on the main pivot pin at the top. The springs pull the shoes towards the center until the shoes rest on the big pivot pin. Yes, those arms are compressed into the cylinder when you install the shoes .. they work by pushing out on the shoes, so of course their normal position is compressed.
Old 02-28-2022, 08:41 AM
Thank you so much for that explanation. Ok, I'm moving forward and great to always learn something. I really appreciate it.
The Following User Says Thank You to Malibu For This Useful Post:
Old 02-28-2022, 08:56 AM
dataway's Avatar
In case you don't have a picture/diagram
Old 02-28-2022, 09:07 AM
Thanks again!
I took a pic of the brakes before I took them apart but these pics are great since they list the proper names of each item.
