Old 03-11-2022, 05:40 PM
Scott Thelander's Avatar
Default 1969 GTO LeMans Tempest dash stuff
I have had a very nice 69 fuse box harness stashed for 20 years in a box
from a 60.000 mile 2 door htop I should not have parted out ,,,
NO cut wires
non ac but can be converted
radio plug intact
lighter wire shows no overheating
non rally gauge ... 2 wires swap at the cluster and I can swap those correctly if needed
real nice lettering on the box .... still has some color striped fuses in it
550 shipped .... super soft flexible wiring,,, no repairs ,, a couple fuse clips show spots of partial oxidation but it will clean up easily
69 ac heater control real nice with single cable and both switches 125
other ac parts available also dash pad core with good radio hole
and very minimal surface rust on the rear
radio support bracket 20
a real decent original glove box liners 15-50
ac and non ac kick panels
emergency brake pedal assembly 35
brake pedal automatic 25
rally gauges and std clusters clocks n tachs
I will be posting some 69-72 radios soon
ash tray and holder bracket 35 ... fiber optic ash tray light ,,,
SWEET lighter assembly rochester.. and a casco
steering column plastic toe kick panel 25
a couple under dash column covers,,, blue ... green .. black ....
69 ac heater box inside and outside .. from a dry interior car
69 only reverb switch and wiring and box
set of 4 real nice original door hinges 175 ready to hang singles 10-60 ea
nice floor harness fuse box to trunk with sleeve 50
offers on some items considered
Scott
2o6-4six5-9165 call or text till 10 pm pacific time
ID:	585951   Click image for larger version
ID:	585952   Click image for larger version
ID:	585954   Click image for larger version
The Following User Says Thank You to Scott Thelander For This Useful Post:
Old 03-14-2022, 10:06 PM
pontiacman63383 pontiacman63383 is offline
Do you have the center ac vent assembly above the hvac controller?
Old 03-16-2022, 01:39 PM
sorry
I do not
ac controler and the surround
but no center vent assembly
Old 12-04-2022, 01:09 PM
nmoreilly nmoreilly is offline
Still have the 69 reverb stuff by any chance ?
Old 01-05-2023, 04:49 AM
Oh my I just saw this reply
I do still have some 69 reverb items
Are you still interested??
Old 01-05-2023, 06:44 AM
Yes, you can feel free to PM with what you have, with pics and prices if that works for you. Thanks
Old 01-05-2023, 04:36 PM
Here’s pictures
I took last nite
Scott
I also have a Grand Prix reverb and harness
But no switch or fader
ID:	604610   Click image for larger version
ID:	604611   Click image for larger version
ID:	604612   Click image for larger version
Old 01-21-2023, 07:09 PM
bump
