Old 03-19-2022, 03:20 PM
TA-71 TA-71 is offline
Default HEI wiring
I am converting from Points to an HEI, while running my 12v wire to the fuse box I found a connector plugged into the ignition plug on the box. It is 2 wires molded into 1 connector. Any idea where this goes or what it’s for?
1971 Trans Am - Sold
1977 Can Am - Sold
2002 Trans Am Firehawk - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
1972 Trans Am - Sold
1970 Trans Am - Current Project
Old 03-19-2022, 08:00 PM
Looks like someone wanted power for two sources. Radio, etc.? If you were to unplug it and see what didn't work, you could figure from there.
Old 03-19-2022, 08:20 PM
After some research it looks like it could be the wiring harness for the tach. I wasn’t aware the tach needed to be powered via the fuse box.
1977 Can Am - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
