I am guessing this bracket in incorrect.
This attaches the PS pump to the head. I am getting a bit of belt slip at 3000 rpm The rear bracket. 1971 engine.
........I'm just learning as I go....... |
Do you have more then 1/2” of up and down play in the longest section of the belt?
I do stuff for reasons. |
Looks right to me. I have the same issue since I replaced the belt.
All adjustment is used up on mine and it's still too loose. Shorter belt needed.
Triple Black 1971 GTO |
No, the rear bracket is correct. Do the water pump and balancer pulleys align with the ps pulley?
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
They look to be off about a 1/4 inch. Maybe. Pretty darn close.
New belts and new pulleys I have tightened and loosened the belt. March polished pulleys. Can a heavy duty clutch on the fan cause this. Sent from my SM-G930V using Tapatalk
1/4" misalignment won't work. Something is wrong. But, no, the HD fan clutch won't cause the squeal. Make sure you have the right pulleys, or space the ones you have so they align
Make sure spacer is behind the front bracket. If it's not in there when tightened, it will cause belt to not line up.
I had this problem years ago and would sling belts no matter what I did or what belt I ran. As soon as I revved it hard it would sling belt This may not be your problem. It doesn't hurt to check. Sent from my Moto Z3 Play using Tapatalk
You never know what I might have that you are looking for. EMAIL me. Also check out my other ads here on PY. Just click on user name to view other ads. USPS Money Orders or Wal-Mart to Wal-Mart money gram wire transfer -preferred payments. If Payment doesn't show up in 3-4 days, I move on to the next person that wants it. Serious Inquiries Only - Shipping Isn't Free. |
Is there a spacer at rear lower mount to pump and front lower mount to pump. Can't see in photo.
The Following User Says Thank You to West Coast GTO For This Useful Post: | ||
Thanks guys.
I am going to try it again. Thanks for the drawing and help. Sent from my SM-G930V using Tapatalk
