I've been researching the camshaft removal tools that thread into the nose of the camshaft to help with installation. They're not that expensive, but the shipping is a killer. I'm thinking that I can get a long bolt or threaded rod to do the job for way cheaper. I just need to know the size and thread pitch of the receiving end of the cam. Anyone?
1/2"-20 Fine thread. https://www.jegs.com/i/ARP/070/190-1001/10002/-1
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick. Best so far 9.95@135 mph. 1.39 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exhaust 950 Quickfuel. |
The cheapest and many times best Cam install or removal tool is a another person to support the end of it.
First remove the gear, then remove the thrust plate and then put the gear back on with the bolt only finger tight. Having the gear on the nose gives you at least 60 to 70% more control!
I do stuff for reasons. |
Check the hold down bolt for your spare tire in the trunk, it may be the right size.
Nah, if anything that’s 3/8”, 1/2” is like a head or main cap bolt.
Another choice would be a rear shock bolt...........
1965 LeMans Post Coupe..............I'm not waitin for the undertaker....I'm lookin forward to the uppertaker!..... |
no, it is 1/2-20 as stated. I have a bolt that size welded to a 2 foot stick of tubing.
Other end is 14mm-1.5 for LT cams. |
Whenever I assemble an engine I start with the cam. I stand the block up on end and feed the cam in straight down. Easy Peasy. I find it better to get the cam in and turning free before I load the crank, etc, in the block. Billk
| The Following 3 Users Say Thank You to flat-bill For This Useful Post: | ||
Yes. And if there are issues with the cam tunnel best to find out before the crank and friends are installed.
Have any good fortune with exhaust manifolds, yet?
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
I put cam in first. Block on stand upside down guide the cam in is the way my uncle taught me.
DragStarLeMans |
| The Following User Says Thank You to Drag Star Le Mans For This Useful Post: | ||
But this cam is for the 400 that's in the LeMans currently. It's a '74 400 and wooo it's a dog. It's got great even compression across the cylinders and seems solid but it's got no power. So I'm getting this Summit 2800 camshaft. Very tame with the 204/214@ .050, 112 LS. But an improvement I hope and I need the vacuum to run Power brakes, A/C and Cruise. |
Upside down or on its end? I don’t see how upside down is any different than right side up.
In other words up side down in the engine stand with the open crank case facing up/ you and the crank out.
If your putting the cam in on your own you have much more control.
Ok, that make sense with the crank out and upside down you don’t have to deal with the lifter bores.
The cam is the FIRST part installed during the engine build. Crank is next, then the timing set and #1 rod/piston to check the ICL or intake open point @ .050". Hell of a lot easier to turn the engine and make adjustments only dragging one piston and rod around in there.
Plus with the cam in first nothing is in the way from the underside so you can help it onto the next journal if/as needed.....and NOTHING sucks worse than getting the spinning assembly in place, installing the cam, then finding out you have a cam bearing alignment issue and it has to come back out, the spinning assembly back out, and cam bearings attended to or replaced..........FWIW......
| The Following User Says Thank You to Cliff R For This Useful Post: | ||
What about switching the cam out on an existing engine?
What heads are on the 400?
Seemed like you heard the round port engine run? If Im remembering... that round port engine has a fairly radical cam in it. I’m guessing your 400 is a low compression engine....a hot cam in a low compression engine is a recipe for disaster....
Yea, so i was wondering why degreeing thecam was tought this go-around: all 8 slugs dragging the torque up. Shoulda cammed and just done CYL 1.
