Old 04-08-2022, 05:24 PM
Burbach 174 Burbach 174 is offline
Default 1960 Axle Flange Gasket - Vendors have wrong part
Looking to see if anyone has a better part number. The paper axle flange gasket which goes behind the backing plate comes up with Fel (Fail)pro 5188 which doesn't match up at all.. `The various online vendors including blokes selling parts on Ebay list that wrong part.. I did use Permatex Great Stuff for now but would rather use the correct seal.
Old 04-08-2022, 09:22 PM
If you can't find the correct part get some gasket material and cut your own. It shouldn't be too hard.
Old 04-09-2022, 12:24 AM
If it is the thin, paper-like material I wonder if you had an AutoCAD .dwg file or similar if you could simply print it out then cut it to shape?
Old 04-09-2022, 09:29 AM
peters23 peters23 is offline
This place has a lot of parts for 9.3 rear ends, may have that gasket:
https://fabcraftmetalworks.com/
Old 04-09-2022, 09:42 AM
Stuart's Avatar
Stuart Stuart is offline
Fabcraft does list the gaskets:https://fabcraftmetalworks.com/produ...-assyra6-0610/
Old 04-09-2022, 02:07 PM
mgarblik mgarblik is offline
The Fabcraft ones fit my 62 axle housing just like originals. Or you can make your own easily.
Old 04-09-2022, 08:48 PM
Oh wow, that's great. Not only do they have other things I may need, they're just one state away to the west. Thank you!
