Old 04-09-2022, 07:49 AM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Default Transmission fluid
What's the preferred transmission fluid for a drag race application? I've been using Type F fluid for years in my TH400. I just got my transmission back from the shop. They only recommended to run full synthetic fluid but didn't say Dextron or F . I heard Type F was a better fluid many years ago I have even heard of guys running John Deere hydraulic fluid but what's the consensus?
Old 04-09-2022, 08:40 AM
455 pontiac's Avatar
455 pontiac 455 pontiac is offline
I run ATI super F. I know guys who run the JD with no issues.
1969 LeMans..Liberty Blue
2001 WS6..Sunset Orange
1973 Pro Street Firebird..Lucerne Blue
The Following User Says Thank You to 455 pontiac For This Useful Post:
Old 04-09-2022, 09:07 AM
lakefect lakefect is offline
just had my glide freshend after 8 seasons running Redline atf, needed nothing not even a new filter!!
Old 04-09-2022, 10:05 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
In my Rossler 210XHD, I've used John-Deere-Hy-Gard-Transmission-and-Hydraulic-Oil-TY6354 and currently using TCI-950650 Max Shift Synthetic Transmission Fluid after having the converter tightened up.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
The Following User Says Thank You to RAIV-Z For This Useful Post:
Old 04-09-2022, 01:27 PM
gogtogo's Avatar
gogtogo gogtogo is offline
ATI Type F.
Old 04-09-2022, 05:24 PM
I've heard the John Deere fluid tightens up the converter a little. Did you find this too?
Old 04-09-2022, 08:52 PM
GoatZillaRacing's Avatar
GoatZillaRacing GoatZillaRacing is offline
Coan Transmission and I recommend AMSOIL Multi-Vehicle Spec ATF. Amazing stuff. Read all about it https://amsoilcontent.com/ams/lit/da...tins/g3110.pdf
Get yours at www.InjunOil.com
Randy Repp
1964 GTO "GoatZilla"
1964 GTO "Injunuity" A/FX Nostalgia Super Stock
220" Rear Engine Pontiac Powered Dragster
https://www.facebook.com/PontiacSpeedShop/
https://www.facebook.com/GoatZillaRacing/
https://www.facebook.com/groups/RebuildExcitement/
https://www.facebook.com/Call1844RacersRV/
https://www.facebook.com/groups/INJUNWARS/
Old 04-10-2022, 09:45 AM
chuckies76ta's Avatar
This has been my understanding also. Run Type F. I just built my TH400 last summer and ran it with Type F. Pulled it apart this winter and it looked like new. I would love to try a new technology fluid but I'm wary of results. It's like don't fix something that's working. I realize that synthetic oils will handle the heat better, but clutches work on friction and they have to grab. I don't have enough experience to
experiment I guess. Maybe there's a reason ATI sells Type F fluid. http://www.atiracing.com/products/tr...rts/superf.htm
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick.
Best so far 9.95@135 mph. 1.39 60 ft.
468 with KRE D-ports, Doug headers, 3" Exhaust
950 Quickfuel.
Old 04-10-2022, 12:22 PM
Scott65's Avatar
Scott65 Scott65 is offline
The Caterpillar TO-4 spec hydraulic oil works well too. Probably similar to the Hyguard but I've never used that.
'65 Tempest 467 3650# [email protected]
Old 04-10-2022, 03:48 PM
Hooter's Avatar
Hooter Hooter is offline
Ran ATI type F for years.
67 Bonneville ragtop
Old 04-10-2022, 07:47 PM
Half-Inch Stud's Avatar
When an old fluid like Type F works well on all parameters, then any/all new fluids can at best provide a marginal benefit, if any benefit can be measured.
I cannot imagine the price for Redline ATF.
Since the Price of Type F is high/Quart now, any lower-cost fluid ought be investigated.
Old 04-11-2022, 01:36 PM
Drdach Drdach is offline
I drained and changed filter and added B&H Trickshift to my 1970 TH400 in the 70 Grand Prix....seems to be working well
Old 04-11-2022, 02:50 PM
Dragncar Dragncar is offline
B&M Trickshift is type F with 10% synthetic type F. Been making my own for years.
Old 04-11-2022, 03:50 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
JD Hygard here.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 04-11-2022, 06:12 PM
RAIV-Z's Avatar
Tough to tell, not enough consistent data at the time I tried it.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 04-12-2022, 03:46 PM
Mean Green's Avatar
Mean Green Mean Green is offline
O'Reilly's basic dex/merc. 500+ hits on my turbo 400 and still going strong.
www.lancablingsolutions.com
