Is there a source for production numbers for the Formula birds? In other words, is there a breakdown of more specifics such as colors? A/C? Power brakes? Power windows? Etc.
Jim www.raceV8s.com 1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th. |
Not that I'm aware of.
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
| The Following User Says Thank You to keith k For This Useful Post: | ||
The only place I've seen info like that is in a book titled: "The Definitive Firebird & Trans Am Guide 1970 1/2-1981" by Rocky Rotella.
The info is in the appendix section in the rear of the book, but there are no breakdowns by colors, just options such as the three you mentioned for 1971, (see below). Unfortunately it's not broken down by model, (Formula) and I assume it's for all Firebirds. There are a few exceptions, where the options were only available on a certain model. For example, the L75 455 engine (350 total installed), LS5 455HO (321 total installed), and Ram Air Induction (109 total installed) are all listed as (Formula Only). Power Windows - 2,542 total installed Custom Air Conditioning - 30,493 total installed Power Brakes (except Trans Am) - 27,788 total installed. The most popular option listed is Power Steering (except Trans Am) with 48,352 total installed. The rarest option is a self charging flashlight with 12 total installed. Last edited by eaglesan13; 04-15-2022 at 12:36 AM. |
| The Following User Says Thank You to eaglesan13 For This Useful Post: | ||
here is the post I was trying to remember, this is about as definitive for '71 and '72 as I've seen: http://forums.maxperformanceinc.com/...d.php?t=510747
'72 Formula 455HO TH400, Revere Silver, black deluxe '74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe |
One thing that folks seem to forget with "numbers of options" is that what is a cost option on a Formula, is part of a package on say, an Esprit.
you could take up 6 option listings on a Formula window sticker that a Esprit is listed as standard. This is why you will sometimes see a Formula with a long list, Not much was included in a base Formula and probably 90% got recessed wipers, which was Standard ONLY on a Esprit and T/A. Pats Info is sure interesting...
" Long may we DRIVE !" |
Thank you RicksGTO for the link. Great info posted by Pat Brown back in '07. I remembered seeing it but could not find it. Spectacular!
