Old 04-16-2022, 11:45 PM
GtoFM's Avatar
GtoFM GtoFM is offline
Default '64 power steering conversion notched fan
I am converting my stock '64 389 GTO with a clutched fan to power steering. Do I need to change to a notched fan to clear the PS mounting bolts?
Old 04-17-2022, 07:30 AM
Cardo's Avatar
Cardo Cardo is offline
No you shouldn't need to. The notched fans were only on 1965 models with factory air conditioning. The notch is to clear the shaft / center of the pulley on the power steering pump, those units had a different power steering pulley. If you have any interference issues, something else is wrong, most likely one of the parts you used.
"I know just enough to keep me here, but not enough to get me out"
Old 04-17-2022, 03:07 PM
tallrandyb's Avatar
tallrandyb tallrandyb is offline
And I have a 65 with factory AC and don't have the notch but also clear the PS pump, its close but still enough room to not be concerned. This is on a 66 block but I assume the mounting/alignment is the same.
Old 04-17-2022, 10:26 PM
GtoFM's Avatar
Thanks for the info!
