If I determined a couple weak valve springs both intake and exhaust, are there any recommended sizes for this? I suppose I could replace them all. It's a 90,000 mile survivor car. I found two choices on Rock Auto of 1.76 and 1.98 length. Anything more to consider here? Just trying to keep it simple.
There are the specs for the stock valve springs from my notes, which can be hard to find:
16-VS-446 (GM 519113) Outer Listed Specs: OD=1.375 Free=1.985 Comp=1.203 Measured: OD=1.395 Free=2.020 Solid=0.930 Wire=0.170 16-VS-445 (GM 519112) Inner Listed Specs: OD=0.969 Free=1.765 Comp=1.116 Measured: OD=0.965 Free=1.820 Solid=0.930 Wire=0.125 These are similar in specs to the stock (maybe slightly stronger, but are available at rockauto): Melling valve springs (available at rockauto, same specs as SBI) Melling VS450 Outer: OD=1.390 62# @1.586, 140# @1.134 (lift=0.452, rate=173) Melling VS310 Inner: OD=1.050 31# @1.566, 102# @1.114 (lift=0.452, rate=157) Total: 93# @1.586, 242# @1.134, rate=330#/in Aftermarket springs (such as COMP Cams 988-16) tend to have a higher installed height, typically starting around 1.6". You might be able to use these with +.050 offset keepers, ideally might need to deepen spring pockets a bit. |
