Old 04-28-2022, 04:20 PM
428goat 428goat is offline
Default Is this fixable
Looks like the block moved while getting decked. Welding might work but the tapped hole are another problem. What do you think?
Junk?
The Following User Says Thank You to 428goat For This Useful Post:
Old 04-28-2022, 05:13 PM
25stevem's Avatar
25stevem 25stevem is offline
That is extremely strange!
I guess a crank grinding shop that can weld could fix it.
I do stuff for reasons.
Old 04-28-2022, 05:19 PM
Junk?
Looks like the block wasn’t tied down when the milling head started across the deck. Yes, it is repairable. Brazing would probably be the best technique.
Dr. Thomas Sowell
Old 04-28-2022, 07:22 PM
Schurkey Schurkey is offline
I would expect brazing to be too soft, the head gasket fire ring would brinnell/indent the brass.
Cast-iron welding...maybe. The weldor better be good.
"I" would tell the machine shop to find me another block. This is their screw-up, they should be taking care of you.
The Following User Says Thank You to Schurkey For This Useful Post:
Old 04-28-2022, 07:42 PM
TxSportCoupe's Avatar
TxSportCoupe TxSportCoupe is offline
Yeah… me and someone would be having a problem. They owe you a same or “better” block. No questions. And, an apology. That being said I’ve seen two welders in my life who could fix that like it never happened. Both drunks. I’m sure there is one where you live. But! If I tried it, I’d make it a low compression motor and keep cool. I’d be scared on a big compression motor that it might cough up a weld slug, right through the fender and upside someone’s head sitting next to me. Make ‘Em buy you a block.
Old 04-28-2022, 07:43 PM
Glad it’s not mine. But you are correct the machine shop should find another block
Old 04-28-2022, 07:48 PM
IDK. Someone knows more than me but could you punch it out and sleeve it to create a solid fire ring and then weld up to it? I’d try that as a back up block. To the one they bought me!
The Following User Says Thank You to TxSportCoupe For This Useful Post:
Old 04-28-2022, 08:39 PM
Joe's Garage Joe's Garage is offline
Default Unless that is a 'matching numbers' or some special block, we'd never chance it....
That would be defined in my book as a 'major screw-up by the machinist'.
As mentioned, there would be some serious conversation with the owner of the machine shop. You took him a usable block and he gave you back an UNusable block.
He owes you a new block. Pure and simple.
Good luck!
Old 04-29-2022, 09:11 AM
burd burd is offline
Every trades do major screw ups. Why not ask a engine builder ?
Old 04-29-2022, 09:32 AM
DANTIP DANTIP is offline
Default Block
Ouch!! Hope that's not a matching number block to a high-value car!!
There's a process termed "Lock & Stitch" That looks like it could work for that damage. The process is used to repair cracked blocks. That machined gouge may be able to be repaired in the same manner.
Old 04-29-2022, 09:40 AM
Formulajones's Avatar
I had a used up 350 SBC block that looked like that. It was already .060 over etc.... It was brazed up just as Hurryinhoosier62 mentions and then I continued to use it in a Monza that I raced in UMTR fairly regularly for about 3 years as well as daily drove it, and it was still running fine when I pulled it for a larger CI build. Sold it to another guy who also raced the engine for quite a while.
https://youtu.be/XqEydRRRwqE
Old 04-29-2022, 09:56 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
Somebody gets to keep a trophy! screwhole is not an issue...but DECK THICKNESS is. Yeah SOMONE can weld that!!!! Finding that someone....might be a bit more challenging. If it's NOT a "special" number block...the SHOP should be able to replace it in a couple phone calls. If it IS SPECIAL.....The shop is going to have to make ALOT of phone calls when THEY REPLACE IT!
Looks like they lost an insert on the cutter head. NOTE: nice FLAT touchoff mark on lifter side.....then progressively deep DIVE at the same "arc". If the insert was loose and tried to come out during the interrupted cut (cylinder bore)...I could see that happening. And immediately making a phone call to REPLACE YOUR BLOCK!
Old 04-29-2022, 10:03 AM
track73 track73 is offline
Yes. it can be fixed. I'm surprised the machine shop didn't send it to a competent welding shop. Because the gouge is open ended the cast iron weld will have a place to expand. But I wouldn't pay for the procedure.
1979 Trans Am WS-6 .030 455 zero decked
flat pistons
96 heads with SS valves
041 cam with Rhoads lifters 1.65 rockers
RPM rods
800 Cliffs Q Jet on Holley Street Dominator
ST-10 4 speed (3.42 first)
w 2.73 rear gear
__________________________________________________ _______________________________
469th TFS Korat Thailand 1968-69 F-4E Muzzle 2
Old 04-29-2022, 11:34 AM
FrankieT/A's Avatar
Please let us know what the ultimate resolution is/was.
Old 04-29-2022, 12:06 PM
mgarblik mgarblik is offline
That's one heck of a gouge! But accidents happen. Depends on the type of surfacer how that happened. If the cutter is located under the block, I agree the block must have dropped on it. If the cutter is overhead, it's a little more puzzling how a groove that deep would have happened. I can tell you I feel terrible when something like this happens, but it does sometimes. The very worst "screw-up" machining I have personally been responsible for was a numbers matching DZ 302 block for a Z28. Had it in the Computerized Rottler F5A boring mill, all set-up and ready to cut the 3rd of 4 bores on one side. You hit the go button and the centering fingers are supposed to come out automatically and center the cutting head, then release and begin boring. This time, 3 of the 4 fingers came out and the 4th one hung up in the cutter head and didn't center. By the time I realized what was happening and hit the emergency stop it had bored an offset hole, about .200" to one side, about .150" deep. Horrible, horrible nightmare. Much worse than that gouge. We fixed it by locating the bore of the untouched area manually and installing a custom flanged sleeve we had made by LA sleeve. It was quite an ordeal. But we saved it.
Your block, I would probably pre-heat it gently and weld the groove in with a silicon bronze welding rod. Build it up and then resurface it. I would also probably offer to do the bare block work for no charge as a good faith effort to
make it right for the customer. I see no performance issues with repairing it. It's away from water and shouldn't be an issue. Best of luck with it.
Old 04-29-2022, 04:13 PM
25stevem's Avatar
Brazing too soft?
I without fail I always find it harder to grind then cast iron, unless we are talking about cast iron that has been over heated and turned blue as on flywheels and brake drum’s.
When I have ported heads that have been fixed by brazing I have to use a stone and then sand the excess braze down to level it off with the surrounding iron so I don’t dull my Burr’s.
Old 04-29-2022, 04:21 PM
I will report back when I hear what was decided to do with that block. Fix or replace. Might be a while.
Old 05-04-2022, 03:11 PM
dirtbird5x dirtbird5x is offline
The right guy can weld it… I’d find a shop the specializes in cast iron head repair..
Definitely worth repairing
Old 05-04-2022, 08:23 PM
AIR RAM AIR RAM is offline
I think its been mentioned... If you are considering having it repaired and not demanding the shop replace that block I second the method of preheating the block and welding the damaged area, resurface it then sleeve it. I think it will be good as an almost used/re-manned block. The sleeve would limit the direct combustion heat and pressure from stressing it over time.
I feel the block needs to be put in an oven and welded hot... I'm not sure of the best temp, but I am sure someone knows.
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
The Following User Says Thank You to AIR RAM For This Useful Post:
Old 05-08-2022, 03:56 PM
AC445 AC445 is offline
Default Iron Repair
Back in the mid 70"s the head of a Ram IV valve stock valve broke off and damaged the combustion chamber of a 722 head. After asking many racers and machine shops I took the head to Indy Cylinder Head and they repaired it. So way back then I learned,.the hard way, do not trust Ram IV valves even with flat tappet spring pressures. I don't know if they still repair cast iron maybe another member does.
