Old 05-11-2022, 12:15 AM
Judges4u Judges4u is offline
Default 1965 GTO Reef Turquoise Parchment Interior PHS Documented
Located Waldorf, MD
LINK TO 170 ICLOUD PICS ***RUNNING CAR PRIOR TO RESTORATION START
https://share.icloud.com/photos/0acy...TGiU1vu1yTvMaw
Two purchase options.
Option 1: $15,500.00 Option 2: $12,000.00
You own the GTO and all the parts listed below.
I'm including two 1970 HO 455 engines. The WA block is 4 speed 4 bolt main block (bare block) for a GTO or Trans am, and the complete YH block for a big Pontiac car; the YH engine has the correct crankshaft used in the WA block.
NOS Brand new Borg Warner Super Power Brute T-10 Rock Crusher transmission with iron case and nickel gears. This was a GM aftermarket transmission that was sold through speed shops during the 70's and 80's. A highly desirable transmission......considered one of the strongest transmissions of its time. Used rebuilt cost $2500-$4000
you own the GTO AND…all the parts below except the following ITEMS: two 455 HO engines, the new BW T-10 Super Power brute transmission, the new Zoom 3:31 ring and pinion set for 12 bolt, and NOS 4:11 gears for 10 bolt differential 4 pinion posi.
- New interior restoration kit (seat covers, cushions, etc)
--Three sets of fenders
- Two sets of doors.
- Two front bumpers
- Two rear bumpers
- Two rear panel Pontiac panels
- NOS felts for 65 GTO SOF Seal weather stripping
- 4 REPO 65 Rally I center caps
- 6 REPO 65 GTO Bumper lens
- New Sets of FELPRO engine gaskets
- 2 brand new Borla Exhaust manifolds
- 1 additional automatic 65 GTO radiator
- 1 additional 4 speed 65 GTO radiator
- Two 65 GTO fan shrouds (one has been galvanized coated)
- 2 new Monroe shocks HP 4959
- 2 new Monroe shocks 3041
- 2 new Monroe shocks HP-4087
- New Hays clutch for 65 GTO
- 4 new drum brake hubs for 65 GTO
- 8 new High dome pistons for 389
- 8 used 389 pistons
- New Turbo 400 rebuild kit
- 2 used moon hub caps
- New repro 65 GTO battery tray
- New DR429X copper distributor caps for 65 GTO
- Restored right and left headlight frames with new halogen lights
- NOS window felts, etc
and much more...
- PHS DOCUMENTED GTO, REEF TURQUOISE, AUTOMATIC COLUMN SHIFT, BUCKET SEATS, PARCHMENT INTERIOR
- ORIGINAL OWNER PROTECTO PLATE, ORIGINAL OWNERS MANUALS
- ALL ORIGINAL BORN WITH FACTORY DRIVE TRAIN.
- 335 HP, 10.75 COMPRESSION
- BUILD DATE: 5TH WEEK MAY 1965
- BLOCK CODE: YS – ORIGINAL / CORRECT FOR 1965 AUTOMATIC
- BLOCK CASTING NUMBER: ORIGINAL 9778789
- BLOCK DATE CODE: K204 NOV 20 1964
- HEADS: #77 ORIGINAL & FACTORY CORRECT
- INTAKE: ORIGINAL 8776816 CORRECT FOR 65 GTO 4BBL CAR
- CARB 4BBL: ORIGINAL CARTER 3896S FOR THIS 1965 GTO AUTOMATIC
- TRANSMISSION: 2 SPEED SUPER TURBINE 300 AUTOMATIC
- DIFFERENTIAL: 12 BOLT PONTIAC, ORIGINAL 10 BOLT DIFFERENTIAL INCLUDED, ORIGINAL DRIVESHAFT,
- FRAME AND MOST OF THE BODY IS SOLID, SMALL AREAS OF RUST
- NEEDS PATCH PANELS ON REAR QUARTERS
ID:	590570   Click image for larger version
ID:	590571   Click image for larger version
ID:	590572   Click image for larger version
ID:	590573   Click image for larger version
Old 05-11-2022, 12:21 AM
Default Pics
More pics
ID:	590575   Click image for larger version
ID:	590576   Click image for larger version
ID:	590577   Click image for larger version
ID:	590578   Click image for larger version
The Following User Says Thank You to Judges4u For This Useful Post:
Old 06-08-2022, 05:04 AM
Sold. Thank you James
