Old 06-03-2022, 04:30 PM
nascar_37_2001's Avatar
nascar_37_2001 nascar_37_2001 is offline
Default 1966 Pontiac Tempest Restomod
1966 Pontiac Tempest Custom
Fuel Injected - Resto Mod/Pro-Touring Build
Cameo Ivory White
Medium Blue Bench Seat Interior
488 Stroked Pontiac Engine
Built Turbo 400 Transmission
Power Steering & Four Wheel Power Disc Brakes
Protec-o-Plate and owner’s manual
Only 10 Miles on Fresh Build!
Paint & Body:
• Repainted in original Cameo Ivory
• Very straight bodywork and decent panel alignment
• I am very picky and have judged at car shows
o The body work is a solid 9 out of 10
o The paint is 9.5 out of 10
Engine:
• Fresh build with proper dyno break in - dyno sheets and video included!
o 544 horsepower – 616 ft. lbs. of torque
o 10.5:1 Compression – 93 Octane
• Original Pontiac 400 block
• Scat - 488 stroker crank, pistons and big block Chevy rods
• Butler\Comp Cams – billet hydraulic roller custom grind – 236/242 .521/.540 114 LSA
• Lunati roller lifters
• Comp Cams Ultra Gold roller rocker arms 1:65 ratio
• Edelbrock Performer RPM – Ram Air IV - round port cylinder heads
• Edelbrock Torker II Intake
• Holley 800 cfm Sniper Electronic Fuel Injection
• All ARP Bolts
• K&N air filter
• Canton road racing oil pan
• High volume oil pump
• High flow water pump
Transmission:
• Fresh built by J.W. Performance Transmissions
• BPO Turbo 400 long tail shaft case
• Custom 12 inch 2,200 RPM converter
• Full roller bearing sprag
• High volume finned aluminum pan
• Brand new SFI flex plate
• ARP Bolts
Rear End:
• Moser Engineering – Ford 9 Inch MusclePak
• 3:00 gear ratio
• Disc brakes
• Powder coating, fill and drain options
Wheels & Tires
• 17 Inch American Racing Torq Trust Wheels
• Brand new Bridgestone Potenza performance tires
o Fronts are 235/45/17
o Rears are 245/45/17
• Wheels were completely machine polished before new tires were mounted
Suspension & Steering:
• UMI Stage II Kit
o Adjustable tubular upper control arms
o Tubular lower control arms
o Adjustable front sway bar
o Tubular rear control arms
o Tubular frame braces
o Solid rear sway bar
o 1 inch drop coil springs
o Hotchkiss 1.5 Street Performance Series shocks
• Brand new Borgeson quick ratio steering box
Interior:
• Brand new Dakota Digital Dashboard with GPS speedometer
• Interior is low milage original however the following components will come with the car to complete the restoration:
o Brand new ACC carpet set
o Matching ACC Custom Pontiac emblem floor mats
o New headliner and matching sun visors
o New dome light
o New rear view mirror
o New arm rests
o New door panels (on order will be delivered or shipped to buyer)
o New front and rear seat covers (on order will be delivered or shipped to buyer)
o New front bench seat foam
o New rear seat cushion material
Stainless & Chrome Trim:
• Front bumper is an original that has been re-chromed and shines beautifully
• Rear bumper is aftermarket and shines very nicely
• Rear window trim is new and in excellent condition
• Front windshield trim is new and in excellent condition
• Original front grill in excellent original condition (nicest I have ever seen)
• Headlight bezels are new and in excellent condition
• New arrow head hood emblem
• Side mirror is new and in excellent condition
• New drip rail moldings included with the car but have not been installed
• The post window trim is original and the aluminum shows some oxidation
• Tempest Custom side molding trim is in original condition – nice but some imperfections
• The fender and quarter panel emblems are brand new reproductions
• The rear “Pontiac” emblem is a brand new original NOS unit
Glass:
• Windshield is new
• Rear window is new
• Side glass is original and in great shape – windows roll up and down very smoothly
Under Carriage:
• The frame and under carriage have been painted chassis black
o Not concours finished but more detailed than a driver quality vehicle
• Complete Flowmaster American Thunder dual exhaust system
• Floorboards and frame are solid and rust free
• Brand new custom built drive shaft and yoke
• Powder coated tubular transmission cross member
• Brand new powder coated Holley Sniper gas tank with integrated fuel pump
• Brand new stainless parking brake cables
• Braided stainless transmission lines
• New fuel lines with proper heat shielding
Engine Compartment:
• Every component was replaced, rebuilt or detailed at the time of restoration
• Overall it presents with a show quality appearance
• Brand new Cold Case aluminum radiator with twin electric fans
• Brand new master cylinder and power brake booster
• Newer Interstate battery
• Hedman Hedders with custom ceramic coating by Jet Hot
• Brand new chrome 1 wire alternator
• Brand new high torque mini starter
• New pullies
• Shielded MSD Spark Plug Wires wrapped in insulation
Serious inquiries only, absolutely no pressing need to sell this vehicle so please don’t waste time with low ball offers. The vehicle will be sold on a clean New York State transferrable registration in the current owners name (note that NYS does not issue titles for vehicles older than 1973). I am happy to provide additional photos, videos or schedule an inspection for serious potential buyers. I will work with any legitimate shipping company to ensure a smooth transition at the buyers expense.
$79,995 or best reasonable offer
Walk Around Video:
https://youtu.be/PmbRT1IonNQ
ID:	592095   Click image for larger version
ID:	592096   Click image for larger version
ID:	592097   Click image for larger version
ID:	592098   Click image for larger version
Old 06-03-2022, 04:32 PM
Meant to post in For Sale not Wanted , hoping site Admin can assist
Old 06-03-2022, 07:30 PM
Stuart's Avatar
Stuart Stuart is offline
Discussion moved to the for sale section.
Please include your location, per board rules.
Old 06-03-2022, 07:52 PM
Thanks for moving the thread!
The car is located in Avon NY 14414
Old 06-06-2022, 11:32 AM
misterp266's Avatar
Very nice job! Looks awesome, too bad it’s way out of my price range . . . .GLWS.
" Darksiders Rule "
Old 06-27-2022, 11:01 AM
The new carpet and floor mats have been installed and the price has been lowered to $74,995 or best reasonable offer
Old 06-27-2022, 10:47 PM
Very cool car-
Old 06-29-2022, 09:30 AM
Thank you for the positive comments!
It is now active on eBay as well:
https://ebayvehicle.com/app/G3Vr
Old 07-03-2022, 08:24 PM
promptcritical's Avatar
promptcritical promptcritical is offline
Nice car!
Old 07-06-2022, 01:14 PM
Sale Pending
Old 07-10-2022, 05:28 PM
Sold!
I am in the market for a solid 64-67 Lemans or Tempest and will be attending the Syracuse Nationals this weekend.
