Old 06-06-2022, 08:40 AM
lemansboy70's Avatar
lemansboy70 lemansboy70 is offline
Default Todays dumb question.
I replaced the shift knob and button on my '70 GP automatic. Now the button goes in, but won't pop back up! What did I screw up?
30+ Years with NAPA. Happy to help with any auto parts questions.
Old 06-06-2022, 01:20 PM
Left out the spring?
Old 06-07-2022, 05:40 PM
Gordon Church Gordon Church is offline
The button binds in the bore of the woodgrain shifter handle.. ...I've only recently discovered the issue ...I used a dremel tool with a small drum sander attachment and 120 grit drum and lightly sanded it till the PMD button drops in and moves freely ...did this with the button and woodgrain handle off the car....cleaned up the sanding scratches with plastic polish. The button now sits higher and springs up and down with light thumb pressure.
The Following User Says Thank You to Gordon Church For This Useful Post:
Old 06-08-2022, 09:40 AM
Thanks! I will try that. I was sure I put everything back, but you know how that go's!
Old 06-08-2022, 01:18 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
This usually happens if you pry the button off from the top. It will leave small gouges around the top edge of the knob which then causes the button to hang up.
