Old 06-12-2022, 09:40 AM
das maler's Avatar
das maler das maler is offline
Default Mini starter
Looking to install a mini starter on my 1969 gto with points ignition. Question is will I have to install a diode some where on the factory wiring to prevent back feeding or is this a non issue thanks.
Old 06-12-2022, 12:00 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
I don't think you need to do anything special.
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 06-12-2022, 12:51 PM
I put one on my 68 just a few months ago. The only thing involved was snipping the ring terminal off of the factory starter wire and replacing it with their plug in terminal.
Oh, and you will love the weight reduction.
Old 06-12-2022, 03:47 PM
I didn't make that completely clear, mine is the IMI version and l meant by cutting the starter wire, the 'S' wire from the ignition switch. They include a plug for that wire.
Sent from my moto g stylus (2021) using Tapatalk
Old 06-13-2022, 12:59 AM
dataway's Avatar
dataway dataway is online now
IMI on mine too ... very simple installation, works great.
Old 06-13-2022, 03:38 PM
Can you access the block drain plug with the mini starter installed? No can-do with the factory unit.
