Old 06-15-2022, 01:50 PM
Silva455 Silva455 is offline
Default 1970 Firebird Rear Deluxe Seat Belts
Hi Guys,
My car is missing the rear seat belts, so I am looking out for those. But I have no idea what set up I need, for example, is there retractable belts in the rear like the front? It seems the buckles are chrome verse the black since its a deluxe interior. Anyone have any pictures they can share, so I know what I'm looking for please? And last question, does the inside belt move around? Meaning, does the bolt bottom out so that the buckle can mover around freely like the front?
Thanks for any help.
Old 06-15-2022, 02:07 PM
The rear belts are strap belts, only the front bucket seat lap belts have retractors.
Deluxe interior and deluxe seatbelts were separate options, ordering a deluxe interior did not get you the deluxe seatbelts, those had to be ordered separately.
Yes, the bolts allow the belts to move around.
Attached are pictures of a set of deluxe seatbelts taken from a 1970 Firebird.
Welcome to the boards.
ID:	592835   Click image for larger version
ID:	592836   Click image for larger version
Old 06-15-2022, 02:18 PM
Thank you for those pictures! They match what I have in the front, so at least that's right. Now just finding them is the problem.
Do you know if the inboard ones swivel on the bolt, or are they locked down when the bolt is tighten?
Old 06-15-2022, 03:46 PM
Formulabruce's Avatar
The inboard females bolt to the hump. As I recall they don't move and the bolt is threaded to the head. This is off memory on the 70's that I have had.
Old 06-15-2022, 05:31 PM
Thank you for that clarification. Very helpful.
Old 06-16-2022, 02:00 AM
Trevor78 Trevor78 is offline
You can get an 'original style' 3-point for the rear from Morris with GM chrome buckles. But they are limited as no longer have license to use logo, or ever did. It copies the original 3-point rear belt option but improved with retractor on parcel tray. They also have the non-retractor version lap belt only if req.
Old 06-16-2022, 04:24 AM
1970 Manual shows anchor bolts for inners uses the shouldered bolts, often would uses nylon bushes as crush sleeves, not shown, so movement could occur but stay upright at any angle.
Old 06-17-2022, 12:59 AM
I'll check them out and see if that might be an option.
Thank you.
Old 06-17-2022, 09:26 PM
Direct link for 3-point rears. Already out of GM emblems, may be some stockists out there still with some.
https://www.morrisclassic.com/produc...t-seat-belts-1
Old 06-18-2022, 09:25 AM
RLEngland RLEngland is offline
I've been curious about the Deluxe Seat Belt numbers. Here's the numbers for Standard belts.
1970 Firebird/Trans Am/Camaro Standard Seat Belts
Front Seats:
IRVIN Model # 2004, 15A70, 22" (Retractor)
IRVIN Model # 2004, 12A70, 30" (wo/buckle)
Shoulder Harness:
IRVIN Model # 2050, 13A70, 36" (w/buckle)
IRVIN Model # 2050, 13A70, 29" (wo/buckle)
Rear Seats:
IRVIN Model # 2910, 9A70, 32" (wo/buckle)
IRVIN Model # 2910, ?, 15" (w/buckle)
Old 06-18-2022, 08:35 PM
Ramairnacho Ramairnacho is offline
Default Rear belts
Hear is a pic of mine. Mine aren't black they chrome, so I conclude they deluxe. Hope this helped. I installed a new carpet 25 years ago so my belts might have got switched from right to left
Old 06-18-2022, 11:13 PM
Great information. And thanks for the size break down, that's very helpful.
@Ramairnacho, you got a pic of the tag on those belts by chance?
Old 06-19-2022, 02:25 PM
70FormulaCA's Avatar
70FormulaCA 70FormulaCA is offline
Would the deluxe seatbelts option appear on the PHS?
70 Formula 400 Auto non-A/C
Wanted: 1972 Formula HO - leads very much appreciated.
Old 06-19-2022, 02:49 PM
Default My rear belts
Ok hear is close up pics if you need more let me know. I'm probably going to have then services if they are bad. Please explain to me what tag means too and stamp, I'm curious now. I'll send pgs docs not sure if on there
ID:	593020   Click image for larger version
ID:	593021   Click image for larger version
ID:	593022   Click image for larger version
Old 06-19-2022, 05:09 PM
Belts-Custom on the invoice copy is same as deluxe belts in other Pontiac literature. From '66 up that signifies the brushed style buckles.
-The Model number indicates the exact model of vehicle the belt originally was built for.
-Even owning half a half dozen original dated Pontiac Master Parts books printed from late '69 til 81, seat belts are not that easy to research.
-Male & female seatbelt ends changed over the years, so did verions of the standard belts.
-As the years rolled on into the 70's, there began to be more body style specific front retractor assemblies. Upon the intro of mid 72 GM A, F & F -body's, all had a pair of rear seat belt retractors, & there was no interchangeability of the retractors between the body styles.
Typically, missing a set of rear seatbelts & desiring to match the front belts, what one needs to do is find the same style (std or dlx) & vendor belts in order to match. For '71 models the rear deluxe belts were built with smaller sized buckles & matching male ends. This style of rear deluxe belts rolled over for use on early '72 models. Having researched late 72 GM seatbelt usage for years, have yet to find any evidence that deluxe belts were offered for late 72 model F-bodys,
Old 06-19-2022, 10:59 PM
Is belts custom deluex that's my guess.
