Anyone happen to have one they would like to sell? Shipping would probably be to 58201 and I could arrange Fascenal shipment. Thanks.
I believe I have one under the bench, Let me look and I'll let you know.
Shipping may be a killer as I'm on the East coast.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car.
If Jeff can’t help you I can.
Let me know what you find. I'll also see if there are any other items I may need. Going to Detroit and Chicago (Woodward cruise) this summer so it would also be possible to get it shipped there. Thanks.
Pulled out my last 230 Crank. Its been in dry storage and coated with oil so she covered with dirt. No damage and should clean up no issue. I don't keep parts if I don't think their not worth it.
Let me pull the out the other parts you inquired about and I'll get right back to you. Thanks
Real nice Pan and a bin of 230 Rods.
Hey Jeff, what do you want for the pan and rods? I could pick them up at Norwalk in Aug. if you are attending.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 1971 Fiat 130 Coupe 3.2L SOHC V6, ZF 5-speed 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 05 Dodge Magnum 3.5L SOHC V6 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
Jeff,
Sorry the pan and a rod were/are for Rebel. Do you need 230 Rods?
I may, I have a set of the old group buy 250 forged rods, but I sold almost all of my 230 parts years ago. Then bought a 230 powered bird that needs a engine rebuild
Jeff R, Your 250 rods should work for your 230, unless they are special order. OHC 6 rods are interchangeable between the engines and years. There were variations to them and should not be mixed and matched unless they are confirmed by weight and appearance.
Jeff, Jeff is correct. I found some old notes.
Let me know if you may still need. Jeff
| The Following User Says Thank You to Jeff Hamlin For This Useful Post: | ||
PM sent with shipping info.
Thanks.
Parts are on the way. PM sent.
Thanks again.
