Old 06-17-2022, 08:41 AM
abefromen's Avatar
abefromen abefromen is offline
Default 2nd gen Firerbird alignment
What should alignment specs be for a send gen Firebird with a slightly lowered front end? Is stock ok or should they be tweaked a bit?
Old 06-21-2022, 03:09 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
1/16 toe in,1/2 degree negative camber and as much positive caster as you can get -probably 3 degrees max
Skip Fix
