Old 06-18-2022, 11:15 AM
Poncho60 Poncho60 is offline
Default Gas tank sender rebuild?
I think the sender on my 60 Pontiac is messed up. Can anyone recommend a good source for a possible rebuild?
Thx for any replies.
Old 06-18-2022, 02:52 PM
LKLusza's Avatar
LKLusza LKLusza is offline
I'm not sure they are meant to be serviced, though I could be wrong. I've certainly never heard of anyone doing it. Usually. it's a remove/replace type deal.
Larry
Old 06-18-2022, 04:58 PM
OG68 OG68 is offline
I don't know about the older ones, but I was able to easily disassemble the sender on my 68, clean the internal resistive ribbon, movable contact, and other small items.
ID:	592978   Click image for larger version
ID:	592979   Click image for larger version
2007 Cadillac SRX
Old 06-18-2022, 05:13 PM
25stevem's Avatar
25stevem 25stevem is offline
They may look a bit different from year to year, but they all function the same.
I do stuff for reasons.
Old 06-19-2022, 05:18 PM
The gauge reading is a function of the ohms the sender is measuring. So, I'm not sure if all year Pontiacs have same ohm spec. That is important.
Old 06-20-2022, 09:45 AM
6T5 Cat's Avatar
6T5 Cat 6T5 Cat is offline
Checkout this place.
https://tristarrradiator.com/
[SIGPIC][/SIGPIC
Old 06-20-2022, 10:51 AM
vertigto's Avatar
vertigto vertigto is offline
Per their website...
Special Notice, Please Read. As of March 1st, 2022
Due to an excessive amount of backlogged sending units to be rebuilt we are not accepting anymore units as of this time; our current backlog of 16 weeks being the reason for this decision. We are sorry for any inconvience this may cause.
Old 06-20-2022, 11:39 AM
25stevem's Avatar
Where more then 16 weeks passed March 1st no?
Old 06-20-2022, 06:34 PM
stevep's Avatar
stevep stevep is offline
I have had many fuel senders rebuilt over the years.
Old 06-20-2022, 08:01 PM
What gets rebuilt? The electronics in them?
Old 06-20-2022, 08:29 PM
Post #3.
Polish the resistor ribbon and contact. Check with a multimeter for proper resistance while moving the float.
You can buy the sock and as long as the float is still good, its an easy fix.
2007 Cadillac SRX
