Old 06-19-2022, 11:37 PM
TA-71 TA-71 is offline
Default Power steering pulley with woodruff key removal
How do you remove the power steering pulley with a woodruff key?
I have the pump out of the car and the nut off the threaded shaft. The pulley should just pull off, but it won’t budge..
Any tips for removal without damaging the pulley?
1971 Trans Am - Sold
1977 Can Am - Sold
2002 Trans Am Firehawk - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
1972 Trans Am - Sold
1970 Trans Am - Current Project
Old 06-20-2022, 03:07 AM
64speed's Avatar
64speed 64speed is offline
I would try PB Blaster and gentle use of a pulley puller
Old 06-20-2022, 06:16 AM
25stevem's Avatar
25stevem 25stevem is offline
The pulley is also a .002" press fit on the pump shaft, so if I where you I would take it to a car or truck auto parts store that also makes up Hydro hoses and they can press it off for you without bending the pully.
I do stuff for reasons.
Old 06-20-2022, 08:19 AM
69hardtop 69hardtop is offline
O’Reillys or AutoZone has pullers for free loan that will get this off
The Following User Says Thank You to 69hardtop For This Useful Post:
Old 06-20-2022, 09:58 AM
78w72 78w72 is offline
x2, no need to "press" it off, rent the free little pulley puller from AZ etc & it will come off in about 1 minute including set up of the puller.
Old 06-21-2022, 02:41 AM
lust4speed's Avatar
The one tool you don't want to use is something like a three jaw puller that contacts the outer edge of a stamped pulley. The circumference is very fragile and will warp immediately when any pull is applied. The correct puller fits on the inner slot on the front of the pulley and makes simple work of the removal.
Mick Batson
The Following 2 Users Say Thank You to lust4speed For This Useful Post:
