Old 06-30-2022, 07:19 PM
dan62 dan62 is offline
Default 62 Bonneville horn contact ring
I'm missing the brass horn ring and wire that attaches to the upper column bearing on my dad's recently acquired '62 Bonneville. The bearing is there but the metal ring/wire must have been lost for some reason. Is it possible to replace this ring? If so, what would be the compatible years to look for? Thanks.
Old 07-01-2022, 11:50 AM
webfoot's Avatar
webfoot webfoot is offline
I had 2 columns, if you want I can try to dig my extra up.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 07-01-2022, 03:05 PM
I would appreciate your help at your convenience.
Old 07-01-2022, 03:55 PM
webfoot's Avatar
Assuming I can locate it (seems likely) you can have it for the cost of shipping. I have lots of extra column parts, just let me know if you need anything else.
-Jeremy
Old 07-12-2022, 05:35 PM
Thanks for getting that part, Jeremy. I've got it in and the horn working. Just had to make a spring-loaded contact/insulator for the steering wheel between the horn ring and bearing/contact since the previous owner must have tossed those parts.
Old 07-13-2022, 10:57 AM
webfoot's Avatar
Happy to help and glad you got it working. I better check if mine has that contact installed before I torque the wheel down fully.
-Jeremy
Thread Tools
Display Modes
