Old 07-02-2022, 05:31 PM
ChiefCrazyCanuck ChiefCrazyCanuck is offline
Default CCC What will it make? Engine #2
Hello fellow PY'ers. I have a new engine hitting the dyno next week, and thought to ask an opinion of what could it make.
I posted back in 2017 about a 470" stock block engine that did well (830HP). I have since added some enhancements and it runs decent for what it is. I hope to improve the ET in the fall down to 9.3 ET if possible from a current best of 9.6 at 3600 lbs. Anyway, on to the new engine.
AP 535 CI, IA 2 build (4.35X4.500). JE gas ported pistons with skirts coated and a nice ring package from TS. Napier second, and I think a 15 lb. oil ring. Scat 6.800 rods, SG crank. Canton 2nd gen FB RR pan with trap doors and baffles. AP Crank scraper and windage tray.
AP Tigers (64cc) race ready with my home porting. Intakes ported to match the AP large Tiger porter gasket. Before and after the intakes picked up over 50 CFM on my local machinist's bench. I ported the exhausts only to widen the floor over the short turn, and some exit work. Jesel 1.85 rockers. Should be mid 14:1 CR.
Cam is a Comp grind, 282-304@.050. 117 LSA with ICL at 115. Lift measured at intake valve with lightweight checker springs was .90X" STD cam tunnel, .842" Isky redzones.
Tiger intake home ported to match heads, this manifold is really nice in that it gives lots of flexibility to match much smaller head combos. Cloverleafed on top for an anti reversion plate.
1250 carb calibrated for E-85. Work done by horsepower innovations.
2" hooker second gen F-body headers w/extension. I know, they might be small for the combo.
Moroso 4 vane vacuum pump. I have never used one of these deals, so wish me luck with that learning curve please.
So much appreciation to Frank at All-Pontiac for his help through the build. This deal was a mess when I got it, and he helped me with lots of technical detail and part selection.
To be clear, he didn't have to help with the engine and it's problems as I received it. He did though, and is a stand up guy. Very rare these days!
So, any guesses on output? I am expecting 950 and 750 at least.
Happy 4th. to all!
Old 07-02-2022, 10:28 PM
PAUL K's Avatar
PAUL K PAUL K is offline
I don't know but looks like a nice build. Good luck and Happy 4th to you!
Go fast, see Elvis!
Old 07-02-2022, 11:15 PM
slowbird's Avatar
slowbird slowbird is offline
Sounds like 950hp is possible based on parts (a 55mm cam would really help though)
What was your mph with the 9.6 runs?
Old 07-03-2022, 08:00 AM
chuckies76ta's Avatar
I'm just a novice, but I want to guess anyway. I say over 950 hp. Closer to 1000 hp. I too see the headers as holding it back. 2.5" would be nice. That's a pretty stout N/A engine. We did a AP 505 that made 789 hp and 700 T. It's a baby engine compare to this. JMO. Curious on oil pump selection? And wondering how high it will spin too with the 4.5 stroke?
Old 07-03-2022, 09:14 AM
It ran 138.8, hoping with recent changes that will improve to 140+ this year
Old 07-03-2022, 09:21 AM
Oil pump is a basic melling 80 PSI unit. Hard to say how high it will run, but to get to my goal the dyno will need to indicate 710 - ish lb./ft. at 7200 RPM.
The Following User Says Thank You to ChiefCrazyCanuck For This Useful Post:
Old 07-03-2022, 09:32 AM
Default Pictures
Pictures - Hope this works
ID:	593633   Click image for larger version
ID:	593634   Click image for larger version
ID:	593635   Click image for larger version
ID:	593636   Click image for larger version
Old 07-03-2022, 09:39 AM
Thank you sir!
Old 07-03-2022, 10:05 AM
lakefect lakefect is offline
if that doesnt make 950+ hp something wrong. with all those good parts why did you go with .842 lifters?
Old 07-03-2022, 10:50 AM
That's a good question. Honestly it's what I had to work with, and if you are going with a .904" lifter you should address the cam tunnel as well. It's a lot of expense, and I wanted to use the very expensive pieces that I already had.
Originally, I was going to patch it together so I could race it some more the next year (this being 2017). Then I thought, why not port the heads, the manifold, etc? Even then, I ordered a new standard journal cam with the good events to optimize.
And it has a cascading effect from there. The Star Galaxy forging being used (which was bent, then repaired and straightened) is not the best, so I probably should have purchased a fully counterweighted billet. And probably should have bought a better rod.
I have an aluminum IA2 which at some point will have the best of the best. This silly hobby is dreams constrained by logic and practicality. The logic and practicality are most often opposed, and IMO the reason a lot of builds never happen or end up badly. We will see with this one...
Old 07-03-2022, 06:00 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Sounds like a nice combination. It will make what it makes but 950 is a good target to shoot for…as long as you are satisfied. If it’s sealed up and valvetrain is happy then you should be seeing a great number. What is the intake valve dia? Measure the vacuum in crankcase and intake manifold. There may be some left in the inlet and exhaust. Best of luck with it…and keep us posted.
Jim
www.raceV8s.com
1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th.
Old 07-04-2022, 08:56 AM
Intakes are 2.25", another area where it would have been nice to change (2.300") Thanks and I will for sure, tomorrow is the day.
Old 07-04-2022, 04:54 PM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
good luck travis
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 07-05-2022, 06:11 PM
Originally Posted by mysticmissle View Post
good luck travis
Thank you sir, had a couple of issues yesterday and today but it is on there. I will provide the results once in.
Old 07-06-2022, 07:50 PM
Default Dyno day #1 - Gasoline
Results are in, 897HP and 710 ish TQ. Was very hot, not ideal dyno weather but I think it has a chance. Tomorrow E-85, and 1250 carb.
Engine is in one piece, and runs great with no leaks. Happy with that for sure!
Name:	Gas Dyno Data 1.jpg
ID:	593826   Click image for larger version
Name:	Gas Dyno Data 2.jpg
ID:	593827   Click image for larger version
Name:	Gas Dyno Data 3.jpg
ID:	593828   Click image for larger version
Name:	Gas Dyno Data 4.jpg
Old 07-06-2022, 08:07 PM
johnta1 johnta1 is online now
Congrats!
Sounds great.
Old 07-06-2022, 08:16 PM
Nice Travis. Good day tomorrow.
Old 07-06-2022, 08:21 PM
Congrats!
Sounds great.
Thanks, working at it.
Old 07-06-2022, 10:58 PM
slowbird's Avatar
What fuel and carb were you running for these test?
Nice results far
Old 07-06-2022, 11:45 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Nice results !! Can't wait to see what the big carb and E85 do for it.
