Old 07-13-2022, 08:45 PM
i82much's Avatar
i82much i82much is offline
Default oil level in pan
If i look at my engine from the outside, is there an external landmark that gives me an idea how far up the oil level goes? In other words, if I was trying to draw a line around the outside my oil pan to show where the oil level is inside the pan, where would that line be?
does it come up above the bottom lip of the rear main? chasing some oil leaks and trying to get an idea where the oil would be internally. milodon 7 quart, if it matters.
Old 07-13-2022, 09:10 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I can tel you on my Canton full on the factory dipstick just covers the baffle tray.
Skip Fix
Old 07-13-2022, 09:20 PM
i82much's Avatar
thanks skip. attached is a pic of a canton pontiac pan. based on your comment, i would think it is only possible to have a leak from the rear main unless the engine is running? i don't see anywhere besides the drain plug that could leak with the engine off?
i have a decent leak at the back of my engine but it never leaks when running. kind of puzzled.
Old 07-14-2022, 11:07 PM
i82much's Avatar
just bumping this with a simple question - is it possible for a pontiac v8 that is not overfilled with oil to leak oil from anywhere other than the drain plug? if the oil level is below the rear main, i do not see how?
Old 07-15-2022, 06:58 AM
Elarson's Avatar
Elarson Elarson is offline
Not saying this is exactly your problem....but when the engine is running, the slinger on the back of the crank is designed to throw oil off and away from the seal. When you shut the engine off, the slinger quits working but there is still oil draining down all of the walls for awhile. So it might not be as simple as oil level in the pan.
Hope this expands the possibilities that you consider.....
Eric
The Following User Says Thank You to Elarson For This Useful Post:
Old 07-15-2022, 07:27 AM
misterp266's Avatar
While trying to determine where to put an oil dipstick bung on my Milodon 7 qt pan, I put 7 qts of water in it and checked the distance from the pan rail. I did the same with a 6 qt factory pan. Both came out 4 inches down from the pan rail.
" Darksiders Rule "
The Following User Says Thank You to misterp266 For This Useful Post:
Old 07-15-2022, 08:08 AM
PAUL K's Avatar
PAUL K PAUL K is offline
It's possible for oil to leak from a weld on the pan. Sadly I've seen this too many times on brand new expensive USA made oil pans.
Go fast, see Elvis!
The Following 3 Users Say Thank You to PAUL K For This Useful Post:
Old 07-15-2022, 08:19 AM
i82much's Avatar
thanks all. seems like the leak continues for weeks if i don't drive the car, but maybe it's just the initial leak expanding into the concrete and giving the illusion of a continued leak.
Old 07-15-2022, 09:26 AM
Murf Murf is offline
Yeah, It’s pretty hard to judge the size of a leak on an unsealed concrete floor. Maybe get a piece of hardboard or even sheetmetal where the leak is. It’ll give you an accurate idea of the size of the leak.
Murf
Old 07-15-2022, 10:58 AM
i82much's Avatar
i cleaned up the oil spot and there is new oil on the floor. this is after three weeks of not driving the car.
i am not 100% certain, but it seems extremely unlikely to me that oil from driving three weeks ago is still showing up on my floor.
Old 07-15-2022, 11:36 AM
Tom Vaught's Avatar
Boost Engineer
Sometimes you have a gap when a rear main seal was not trimmed properly.
I know that OMT fought this issue and eventually hung the engine from a cherry picker
at a severe angle and solved the rear pan leak issue.
Tom V.
Old 07-15-2022, 12:47 PM
i82much's Avatar
i dunno, maybe the engine is tilted back far enough that the oil can get up over the bottom of the rear main. seems like it would have to be tilted pretty far.
one really crazy idea would be for me to actually crawl underneath my car and take a look instead of just posting on the internet asking stupid questions. but that sounds like a lot of work.
Old 07-15-2022, 12:56 PM
AG's Avatar
AG AG is offline
Conjecture about what might be the issue is way more valuable than trying to actually find a root cause by looking at it.
The Following User Says Thank You to AG For This Useful Post:
Old 07-15-2022, 01:05 PM
i82much's Avatar
I tell my wife this all the time.
Old 07-15-2022, 01:06 PM
i82much's Avatar
In all seriousness it's helpful to have a visual understanding of where the oil level is so I can do some deductive reasoning. Thanks all.
Next step might be to rig up our Halloween smoke machine to the shop vac and see if I can't get some smoke to show me where the leak is.
Old 07-15-2022, 01:21 PM
Pav8427 Pav8427 is offline
One trick that might help. Carb clean the pan and bottom of block. Once dry spray some Right Guard deoderant over the area. Let it sit. Oil leak will be easy to spot over the residue left by the Right Guard
Old 07-16-2022, 09:17 PM
i82much's Avatar
the uv dye did the trick. looks like a hairline crack in the bottom of the pan. gonna try jb weld for now and see if it holds.
Old 07-17-2022, 08:02 AM
25stevem's Avatar
25stevem 25stevem is offline
I would use silicone gasket maker to seal it up and then JB weld to protect the sealer after it sets.
Apply the gasket maker and spread it and pack it in the pit holes with your finger wet with soapy water.
Let this set up over night and then if need be trim it’s length and width back then over coat with the JB.
I do stuff for reasons.
Old 07-17-2022, 11:23 AM
i82much's Avatar
sounds like a plan. I've always had good luck with ultra grey so I will try that unless someone has a better idea.
Old 07-17-2022, 12:19 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Most prolly a bad weld or a plug/plug gasket leak.
