Old 07-21-2022, 03:07 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Default Rear quarter panel pictures
So my 65 GTO project is tweaked in bot rear quarter areas where the quarter goes to the tail panel and an open gap both sides. Anyone have a picture with eth bumper and tail light housing removed to see how they are supposed to look? And does a "full quarter" wrap around there?
Skip Fix
Old 07-21-2022, 04:51 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
There's a video on YouTube of a guy replacing that back panel on a 65.
Old 07-21-2022, 08:35 PM
Skip Fix's Avatar
Found this one but he is using a partial qtr patch panel on the other side and I have they don't wrap when full do.
Picture of the factory side is the gap that I circled supposed to be there or attached? Mine is tweaked on both sides and goes into the trunk.
Name:	GTO qtr 2.jpg
Skip Fix
Old 07-21-2022, 09:17 PM
hobbygto65's Avatar
https://youtu.be/yRs8Ha1QY0s Try this video.
Old 07-22-2022, 03:45 PM
KCTurbo's Avatar
KCTurbo KCTurbo is offline
I have mine all apart currently and can snap a couple photos after work.
"NSDQ"
Old 07-22-2022, 04:08 PM
Skip Fix's Avatar
Thanks . Mine is just tweaked enough in different spots hard to tell what "normal" is.
Skip Fix
Old 07-23-2022, 05:08 PM
Skip Fix's Avatar
here are pictures of mine. passenger side crunched in at top and torn into tail panel/trunk. Drivers side just a slight tweak below that. and some rust probably from a leaking tail housing gasket.
ID:	594883   Click image for larger version
ID:	594884   Click image for larger version
Skip Fix
Old 07-24-2022, 06:50 PM
Skip Fix's Avatar
A couple more.
ID:	594935   Click image for larger version
ID:	594936   Click image for larger version
ID:	594937   Click image for larger version
Skip Fix
Old 07-25-2022, 05:42 AM
Cardo's Avatar
Cardo Cardo is offline
Here's mine while it was apart. No rot never hit.
ID:	594941   Click image for larger version
"I know just enough to keep me here, but not enough to get me out"
Old 07-25-2022, 09:52 AM
Skip Fix's Avatar
Thanks! What brand rotisserie?
Skip Fix
Old 07-25-2022, 11:49 AM
Cardo's Avatar
I have no idea!! I borrowed it.
Old 07-26-2022, 01:49 PM
geeteeohguy's Avatar
ID:	594991Here's my '65 when I was changing the rear bumper a little while ago. Original paint in that area, and I wiped the frame and you can see the black paint on it. Original body bushings, etc. CA car that has never been rusted or wrecked.
Jeff
Old 07-27-2022, 12:34 AM
MUSLCAH MUSLCAH is offline
Attachment 594990
Attachment 594991Here's my '65 when I was changing the rear bumper a little while ago. Original paint in that area, and I wiped the frame and you can see the black paint on it. Original body bushings, etc. CA car that has never been rusted or wrecked.
The underside of my 64 GP is that white / grey color like yours …my GP is a California car also….original brake and gas lines ,orig tank…a real rust free beauty. Question….why is the underside that color ?
Old 07-27-2022, 05:48 PM
That is years of road dirt. My car has never been restored or out of service. The small section of the frame I wiped with a damp sponge. The rest of the car would be body color or whatever color the primer was, if cleaned. My car also is running the original tank, fuel, and brake lines, and they are like new.
Jeff
