Old 08-01-2022, 12:55 PM
65gto69's Avatar
65gto69 65gto69 is offline
Default 1965 GTO, 4 speed, dougs headers, clutch fork return spring???
Question for all you guys running headers on your 4 speed a-bodies. Where did you attach the clutch fork return spring??? I know the one end is attached to the clutch fork but where did you attach the other end of the spring.
This is on a 65 GTO
Thanks for your help,
Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi.
Old 08-30-2025, 11:01 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Reviving this as I am looking at my 65 project with the same potential issue. Spring hooks on the flange of the exhaust ,manifold.
Skip Fix
Old 08-31-2025, 07:31 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
On one of my cars, I had to put a clamp on a header tube to get a decent anchor for the return spring. Don't remember what I used though.
Old 08-31-2025, 10:47 AM
Skip Fix's Avatar
Thanks. I was under it this week getting all the old gas out of the tank and started to look at that potential issue.
Skip Fix
