Old 08-30-2022, 10:40 AM
TOPHER TOPHER is offline
Default PONTIAC ENGINE MOCK-UP BLOCK
Is there any source for one of those fiberglass or plastic engine mock-up, or display models?
Kinda big for a 3D printer?
Maybe someone has any leads?
Old 08-30-2022, 02:38 PM
Joe's Garage Joe's Garage is offline
Default Haven't heard of any......
Guy we know who've done mock-ups just used either a 'windowed' block or something they have laying around.
Good luck!
Old 08-30-2022, 03:11 PM
Tom Vaught's Avatar
Boost Engineer
I have a Pontiac 400 block that I had a friend "Epoxy UP" the Lifter Bores and I made
aluminum plugs for the Camshaft bores on the front and back of the block.
The oil dipstick location was used to get the crankcase suction pressure, and the
Pan had a stub section (3" diameter) where I could hook up my vacuum source.
The vacuum source was 8 Ametec 115923 Vacuum Motors.
I worked with Ricky Hunt on a similar flow bench (for the Butlers) before they purchased a Superflow
Bench for their shop. I did this years ago and it was written up in a couple of Jim Butler's early Catalogs.
So my block is used for multiple tasks: Flowbench, Mock-up engine for intake and exhaust fitment (turbo)
and Belt drive Supercharger Systems (Vortech Supercharger).
Well worth the effort.
Tom V.
Old 08-30-2022, 04:04 PM
mostly something we can display an intake or valve covers, and just pick up and move. I know there's a million Chevy and Ford plastic blocks, but surprisingly no Pontiac.
Old 08-30-2022, 08:52 PM
Tom Vaught's Avatar
Boost Engineer
Figure the time frame when Pontiac KILLED the Traditional Pontiac Engine.
Not very many car things were made from Plastic in those days.
Tom V.
Old 08-30-2022, 09:00 PM
FrankieT/A's Avatar
Tom V.
Doesn't some isn't doing one now or in the past 20 years...
Old 08-30-2022, 09:02 PM
242177P's Avatar
242177P 242177P is offline
Have you considered taking an oxy/acetylene torch to a 557 block?
The factory made it lighter already, just take things a little (or a lot)
further. Which is the lightest casting, 350 or 400? Doubt it'll ever
be considered a lightweight, but it certainly would make it more
manageable.
And if it's for a display, talk to coupeute about his engine cradles?
Old 08-31-2022, 08:16 AM
Mr Anonymous's Avatar
Mr Anonymous Mr Anonymous is offline
If youre just needing it for external dimensions, just take a BFH and knock the main saddles out of it, that will remove a bunch of weight.
Clutch Guys Matter
_______________________________________
53 Studebaker, 400 pontiac
72 4-4-2 Mondello's VO Twister II
1964 F-85 Home of the 700hp small-block Olds
**Still wanting a 64 Bonneville or Catalina**
The Following User Says Thank You to Mr Anonymous For This Useful Post:
Old 08-31-2022, 09:28 PM
flamedabone flamedabone is offline
I have been using the same mock up block for the last 20 years.
Just a garden variety 350 with yucky cylinder walls. I toss on whatever set of heads are closest that day.
-Abone.
Daily Driver Model A Ford. 389 Pontiac w/6-71. 10.80 @129.5
1933, 1934, 1936 and 1940 Fords, also Pontiac powered.
The Following User Says Thank You to flamedabone For This Useful Post:
