Old 08-31-2022, 08:44 PM
chrisp chrisp is offline
Default MSD Billet advance stop bushing info
MSD Billet advance stop bushing info largest is 18 degree any size info to make 16 14 12 10 bushings ?
Old 09-01-2022, 05:53 AM
chuckies76ta's Avatar
You can take one of the bushings and get someone to custom make you different sizes. Or get inventive and make them yourself. That is what I did to taylor my timing.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick.
Best so far 9.95@135 mph. 1.39 60 ft.
468 with KRE D-ports, Doug headers, 3" Exhaust
950 Quickfuel.
Old 09-01-2022, 08:55 AM
That is what i am doing but need the o.d. for sizing. Do you happen to have a record of yours ?
Old 09-01-2022, 10:49 AM
Sorry Chrisp, I didn't write anything down on bushing sizes. I just had a few done, I believe in my case smaller.
950 Quickfuel.
Old 09-06-2022, 08:24 AM
Don 79 TA Don 79 TA is offline
4secondsflat i think was the place that offered lock out bushings, and at one time would custom make them
i bought a set and use it at the time i was using advance bushings, i have no idea where they are now since i bought them so long ago and had some moves inbetween
worked out nice too
one of them i needed to slightly file one side so it would fit
i don't recall what it limited advance to, but they worked out real well and were cheap
don't know what hardware stores are near you, but i gather if you have some time and patience you might be able to find some bushings close to the size and do a little filing.... i've seen internet posts that some did that
https://4secondsflat.com/MSD%20Distributor%20Tuning.htm
The Following User Says Thank You to Don 79 TA For This Useful Post:
Old 09-06-2022, 08:28 AM
Excellent link
