SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 09-02-2022, 01:49 PM
TB1's Avatar
TB1 TB1 is offline
Default 17081287 800 CFM Quadrajet
I bought two very similar carbs and rebuilt and tested/tuned both on my car, selling this one it works great just was the first one I tested. Parts for rebuild were bought from Cliff as well as Quadrajet power in Texas.
As per Cliffs suggestion following done to the carb.
Idle tubes increased to .037"
Down channel restrictors .055"
Main air bleeds were left alone
Idle bypass air was added to the base plate .0100"
Secondary air flap set to 1.290" according to Cliffs Book.
New completed gasket set and float and needle and seat, .073" primary jets, full tapper primary metering rods with .026" tip, Air horn tapped for adjusting APT . Primary throttle shaft has been bushed, Electric choke conversion and new choke pull off. As I said carb runs great with no issues, does have a slight wicking of the top air horn gasket spent some time with a file and sanding block to get it better doubled up on the gaskets, Will need to have a throttle cable ball or stud added to linkage. No stripped threads or cracked casting etc. coloring on the carb is faded can get better pics if interested. Looking to get $375 shipped from Canada
ID:	597666   Click image for larger version
ID:	597667   Click image for larger version
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt
Old 09-08-2022, 05:36 PM
TB1's Avatar
TB1 TB1 is offline
$350 Shipped
Old 09-29-2022, 08:56 AM
TB1's Avatar
TB1 TB1 is offline
Bump, good running carb with no issues or BS involved with sale/shipping
Old 09-29-2022, 09:03 AM
adamo adamo is offline
What part of Canada are you from? I am in the Toronto Ontario area.
Old 09-29-2022, 10:03 AM
TB1's Avatar
TB1 TB1 is offline
I'm in British Columbia
Old 10-14-2022, 09:49 AM
TB1's Avatar
TB1 TB1 is offline
Bump for a good running carb
Old 12-29-2022, 02:17 PM
TB1's Avatar
TB1 TB1 is offline
Bump for a good running carb $325 shipped
Old 12-29-2022, 06:48 PM
J Druin's Avatar
J Druin J Druin is offline
PM sent
Old 12-29-2022, 08:39 PM
TB1's Avatar
TB1 TB1 is offline
Originally Posted by J Druin View Post
PM sent
PM replied
Old 12-30-2022, 12:04 PM
TB1's Avatar
TB1 TB1 is offline
Originally Posted by TB1 View Post
PM replied
Carb is sold,Thanks J Druin
