Old 09-14-2022, 09:28 PM
Zappa's 68 Zappa's 68 is offline
Send a message via AIM to Zappa's 68
Default Dash Pad Installation
Appears AC cars have different dash pad retention clips? My installation hardware kit has rectangular clips and looks to need 'square'. I have my new 'Just Dashes' original pad coming and want to install correctly.
Any idea where I can get the correct clips? Thanks
Old 09-14-2022, 11:09 PM
OG68 OG68 is offline
AFAIK they are not available except as used. And the used ones usually break when removing the pad.
Old 09-15-2022, 06:56 AM
dataway's Avatar
dataway dataway is offline
You are talking about the two on the outside far left and right that the pins go into? If so, yep, I couldn't find any, think I ended up using one of the originals and opened up one hole to use a rectangular. If you have to open up a hole ... remember to split the difference top to bottom so the pin is still centered.
Old 09-15-2022, 11:47 AM
It amazes me that no one is making those yet. I guess it's certainly easier turn a square hole into a rectangular one than it is to do the opposite.
Old 09-16-2022, 07:15 PM
nytrainer's Avatar
Here’s what they look like compared to the single rectangular one for a non AC car.
On the side shot you can see how these grab on to the edges of the square (or rectangular) cutout in the dash.
ID:	598786   Click image for larger version
Old 09-16-2022, 07:26 PM
webfoot's Avatar
webfoot webfoot is offline
I used a fender washer and a wing nut to hold mine, the repro clips were too rigid imo.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 09-16-2022, 09:03 PM
nytrainer's Avatar
Zappa if you need these 2 clips they’re yours. I’m paying it forward for help I’ve received from many here through the years. My MIL is at an independent living place (Mercer Hill) so we’re there frequently. Of course I can mail them too (but then I won’t be able to see your car in person &#128521 PM me if you’re interested.
