Old 09-22-2022, 11:06 AM
Jim Moshier's Avatar
Jim Moshier Jim Moshier is offline
Default Hydraulic Roller Lifters
Just reading the other post on lifters has anyone tried the New Comp Cams Evolution Hyd Rollers with the cartridge and where they might be coming from? It sounds like it is an interesting design and quiet, we will see!
Part # CCA-85701-16
COMP Cams®Evolution Hydraulic Roller Lifters are the first lifters EVER created using the newly patented Hydraulic Cartridge Technology (HCT)! This revolutionary design offers the most reliable performance of any lifters in the aftermarket.
.842 diameter; 2.475 seat height
.150 travel / preload between .050" to .100"
Will not clear factory valley pans
Jim Moshier
1971 Grand Prix 462ci SD Performance 6x heads
1962 Catalina 389
1968 Firebird 400-455 I haven't decided
"If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan
Old 09-22-2022, 11:35 AM
rohrt rohrt is offline
I asked the same question a while back. Got no response and went with Johnson lifters instead. It seemed like there just more success there.
I like the concept too.
Old 09-22-2022, 11:55 AM
Formulajones's Avatar
Part # CCA-85701-16
Did you buy a set to try??
https://youtu.be/XqEydRRRwqE
Old 09-22-2022, 05:21 PM
tom s tom s is offline
Not sure if they have shipped any yet?They look like the old Shaver lifters made in SoCal but with the insert.Tom
The Following User Says Thank You to tom s For This Useful Post:
Old 09-22-2022, 06:45 PM
This is what they look like and I haven’t had any time with them that is why I asked. I have 2 projects going right now so more info would be good. Thanks guys!
Jim
ID:	599197   Click image for larger version
ID:	599198   Click image for larger version
Jim Moshier
1962 Catalina 389
Old 09-22-2022, 07:32 PM
Exactly like the Comp Shaver lifters out side.Note the lifter body does not go much past the roller pin.Tom
Old 09-22-2022, 09:16 PM
grivera's Avatar
grivera grivera is offline
Thread about them here : http://forums.maxperformanceinc.com/...93#post6327193
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 09-25-2022, 06:19 AM
Tim Corcoran's Avatar
I was told by someone a very reputable Pontiac engine builder that the best hyd roller for Pontiac currently on the market are made by Johnson Lifter, not Hy-Lift Johnson but Johnson. They are expensive most would not be willing to pay that much for lifters, but you get what you pay for.
Tim Corcoran
The Following User Says Thank You to Tim Corcoran For This Useful Post:
Old 09-25-2022, 07:24 AM
25stevem's Avatar
25stevem 25stevem is offline
I can’t see why they will not clear a non EGR factory valley pan.
They don’t look overly tall to me!
What am I missing here?
I mean I can see a issue on a 301 motor for sure!
I do stuff for reasons.
Old 09-25-2022, 09:46 AM
Pontiac Performance Author
Was told by my comp rep:
They are based on the comp solid lifter .
they are about .200" taller.
They have a .750" roller as opposed to the .700" dia. used on the convential roller lifter {857-16}.
The adjuster is removable due to the taller lifter body.
Available soon 2-3 weeks.
Priceing $ 90+ more than 857-16 (WD price sheet) actual price could vary.
The Following User Says Thank You to KEN CROCIE For This Useful Post:
Old 09-25-2022, 09:48 AM
Standard pushrod seat height
Old 09-25-2022, 10:52 AM
That all sounds pretty good Ken. I especially like the bigger wheel
Old 09-25-2022, 12:44 PM
Formulas Formulas is offline
a bigger wheel will change duration on the same lobe as a smaller wheel ?
Old 09-25-2022, 01:00 PM
chuckies76ta's Avatar
If I had to guess, which is what I'm gonna do, I'd guess NO. Pushrod will change lengths.
Old 09-25-2022, 01:01 PM
A lot of benefits, no downside I'm aware of.
One Billy Godbold talks about is the lobe constantly trying to push the lifter back and move the camshaft around as it climbs the lobe, so the bigger wheel you have the less pressure angle you have and more force going straight up the pushrod, so less goofy stuff happening in his words.
Old 09-25-2022, 01:17 PM
a larger wheel is in effect like putting a wider lifter on a flat tappet cam the lobe will come in contact with the lifter sooner in rotation and leave contact later, and thats duration
Old 09-25-2022, 01:20 PM
So what are you saying? or are you answering your own question?
Yes or no!
Old 09-25-2022, 02:22 PM
stating the obvious but looking for confirmation or an explaination to the contrary backed by IQ. not a guess i can get that from my dog
Old 09-25-2022, 02:25 PM
stating the obvious but looking for confirmation backed by IQ.
IQ Now your just showing your true colours. Lol.
Old 09-25-2022, 06:24 PM
Dragncar Dragncar is offline
It would take a very special cam for wider lifter to have any effect in a sft situation.
A larger wheel will get the valve opening sooner and closing later with a roller cam.
With a sft, with say a .842 lifter, as long as the cam is making contact inside the edge of the lifter circle how could a larger lifter make a difference. ?
A sft cam would have to be so large as to dig into the edge of a .842 lifter for a .904 lifter to be of any use. Never heard of it being done either.
The Following User Says Thank You to Dragncar For This Useful Post:
