Old 09-30-2022, 02:31 PM
JUDGE3 JUDGE3 is offline
Default wiper motor power
I have a new wiper motor, have power at the fuse box location for the wipers. fuse is fine does not blow the fuse.
yet I have no power to the wiper switch or out at the motor?
what am i missing? wiring is my weak link. ugh
thank you
Old 10-05-2022, 09:52 PM
Is this with the key on in run position?
Old 10-06-2022, 09:19 AM
yes, key in run position.
Old 10-15-2022, 07:26 AM
cnc's Avatar
cnc cnc is offline
U have a wiring diagram to post ....??
If the bulk head connector has been apart make sure you Have good connection between the two halves
If u have power on both sides of the fuse I would think there is a feed to the motor or the switch out of the bulk connector....
Diagram would be nice to see...
I have a 73 wonder if it's the same?...
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 10-15-2022, 10:40 PM
Don't know what year you have but on the older cars the wiper switch GROUNDS the wiper circuit.
